Regarding rear Motor Mount upgrades for the ITS
ChromaPop
Franklin, TN
PRL versus 27WON versus just leaving it stock? In my case this may be the only performance upgrade I put into the drivetrain besides a K&N Air Filter. Thoughts and opinions?
I recently put in the PRL, and have been very satisfied with that. Just a little more rumble at idle, and when the AC compressor kicks in at idle, but otherwise you wouldn’t even know you had it. Until you go to punch it at low speeds!
TopazM3
KY
2024 LCM Integra Type S
Has anyone tried the urethane insert from Whiteline? It seems like it could be a good compromise with regard to not increasing NVH much.
boosted_canoe
'23 Civic Si
don't put too stiff of mount on there. it can transmit stress to the gearbox and other parts of the car that the rmm would normally absorb. typically resulting in increased NVH but could also potentially crack aluminum bellhousing, block, etc.
