Removing head-up display area
edido
ITS (TEP)
Hi,
Did any of you remove the plastic cover around the head-up display area? If yes, can you please point me to instructions or explain how to remove it?
I heard a rattle from this area after the car was under sun for a few hours. Noticed it when I came to a stop, the car was in 2nd or 3rd gear right before I engaged the clutch. Nothing crazy, but if it's easy to remove, I would add some felt tape there.
Bruce85623
Bruce
Oracle AZ
2024 Integra Aspen Tech, 2019 Miata
I had that issue with my 2019 Accord. I solved it by pressing down on the window and putting a couple of rubber washers between the window and the cover. It solved the problem.
