Spoon Progressive Springs with taller tires
edido
ITS (TEP)
Hi,
I read on CiviXI forum that Spoon fixed their springs and rear is no longer saggy:
https://www.civicxi.com/forum/threa...5mm-r-20mm-f-spacers.54561/page-2#post-908002
I wanted to ask a few questions:
1. Can I assume that Spoon Progressive Springs will perform the same on DE5? If anyone installed them please share your experience.
2. I plan to keep 19" rims but get taller tires 19/265/35.
3. I have spacers, 15mm front and 20mm rear. I read that clearance should be fine.
From what I understood lowering the car by ~20mm with slightly taller tires should be a "net positive" mod.
I would appreciate any insights :)
koatic
Bryan
SouthEast
If you are wanting more rubber go down to 18” for 35”s and keep the outer diameter the same or your speedometer and your tachometer will be off.
