HUD unit not working 2023 Integra A-spec 6MT
jenh70
Jean
Maryland
2023 Acura Integra Aspec 6MT
Since I purchased the vehicle, I have not been able to setup the HUD. I followed the instructions from the manual, but nothing happens. Any suggestions, before I take it to the dealer? Thanks!
You should be able to enable it and modify it using the scroll wheel on the right of the steering wheel.
I think there’s a fuse for the HUD, but I can’t imagine it blown. You can always double check.
BKK Jack
Jack
NoVA
2023 LCM/Red ASpec Tech 6MT
Before I turned mine off (I found it to be more of a distraction than an asset) I noticed that I could adjust the height to the point where it would disappear. Maybe just play with the height and left/right adjustments until it appears?
BackPack
San Diego
2023 Porsche 911 Carrera S, MINI Cooper SE
When I test drove one, I asked the salesman why the HUD wasn’t working. He said it should be on, but the height needed to be adjusted for me. I moved my head lower and sure enough there it was. I didn’t bother adjusting it, but good to know it’s simple to adjust to fit your height and seat placement.
jenh70
Jean
Maryland
Where are the left/right adjustments? Thanks!
BKK Jack
Jack
NoVA
Sorry, I misspoke. There is only height. I thought I remembered seeing left/right, but just checked the manual and the adjustments are for content, height, and brightness.
jenh70
Jean
Maryland
Thank you all for your answers. The issue was the height adjustment. It was too low. I saw the reflection last night and adjusted the height. Thanks again.
BKK Jack
Jack
NoVA
I'm happy you got it sorted. Sorry for the bum scoop about the non-existent left/right adjustment.
