TigerEyeJazz
TigerEyeJazz
2023 Honda HR-V Sport.
Told you.
In the previous clip released by Acura, the engine sound was from a transmission paired to a (Manual/DCT).
My ears still working fine.
Let's see what is the final engine power output.
Will Acura the 2.0T from the TLX?
Will they have the balls to use the 2.0T from the CTR?
I really hope they don't settle for a 1.5T.
The one they had in the teasers before hand weren’t what the Integra was going to sound like. Acura tends to use files for sounds they have saved.
Hondabob
Hawkmoon2007
Civic Si
So the interior shot has me curious, it looks like it’ll mostly be a civic copy. I wonder if that means the drive mode selector on the Type S will be the civic style or the giant dial from the other products in acura line up lol
Integra
Mustang
it looks like a copy of the new CTR's panel so it depends on if the new CTR has its mode elector there or not.
TigerEyeJazz
TigerEyeJazz
So based on this shot it seems like a ton of things can be taken from this.
1: the knob we are used to for the Acura products is not present as you can see it has the Individual mode selected with different driving modes added.
2: no touchpad= touchscreen. As expected the model will likely used an upgraded version of the Civic touchscreen to incorporate the Acura aesthetics. It could also use an updated Acura Touchscreen that could come to other models though I’m going to go with the former.
3: Since it will use the Civic touchscreen, Apple CarPlay and Android Auto will both be Wireless. No more wired control.
4: Two different cup holder setups. Since this is the manual equipped model it has to have the cup holders farther back so you can row your gear uninterrupted (i.e. Civic Type R interior)With the 8 Speed DCT coming it’ll get a regular style shifter location so that the cup holders could be on the side of the shifter like TLX.
These of course are what I interpreted.
Acura Integra Manual Transmission For 2023 Integra Confirmed by Acura! 21DE7495-C089-46B6-9825-5AC576EC7D9A
Acura Integra Manual Transmission For 2023 Integra Confirmed by Acura! 08D00CE3-D71E-4833-BD04-17E164E1D984
KoukiVAB
Northern VA
You guys remember the removed post about the research study?
Based on the Civic Interior, but nicer.
Now I see what the person meant by that.
I wonder what will be replacing the vents as that was mentioned in the post too.
TigerEyeJazz
TigerEyeJazz
Just regular vents I’m assuming. Nothing like the Civic that’s for sure.
jd2157
2024 Acura Integra Type S LCM
Any 2.0 will likely be in the Type-S, the question is will the type-S get a manual or will they do like most makers and the manual is base only. I expect the 1.5T to be the base engine and shared with the new Si. 200-220HP. 230 if lucky. The majority of buyers will be wanting a nice peppy ride with great MPG, and the 1.5 delivers that. MAYBE they could use the Accord 2.0T but I don't see them doing that as historically the base Integra/ILX has been closer to a Civic Si.
On the 2.0T, the Type S will likely get one ya and a version of the CTR motor probably makes most sense. Have the Integra built where the Civics are built, different shell but with all the same power trains.
They’re making a big deal of the manual in that video… I don’t think you do that to then only put it on your base model. Honda has been on the right track lately, so I expect they’ll do a 6M in the Type S.
Acura_CSX_4eva
2010 Acura Manual Transmission + Nav + Heated Leather
Keep in mind that removed post on the research study also mentioned an A-Spec 6 speed manual trim version for 33.5k. If they also have a Type-S 6 speed too I'm gonna be stuck between choosing the A-Spec or the Type-S! ?
TigerEyeJazz
TigerEyeJazz
From what I heard it’ll have both a 6 speed and 8DCT. Take it with a grain of salt till we hear concrete info though.
TypeSiR
Car Driver
On a Twisty Road
1.5T Civic, CTR, MX-5, Fit
Does anyone know what the top button/indicator on top of the drive mode selector is? After comparing it against the new Si shifter and learning that it has an "INDIVIDUAL" drive mode, I think the button/indicator says "INDIVIDUAL" on the Integra. Maybe it lights up (as an indicator only) when INDIVIDUAL drive mode is selected or it may also be a physical quick-access button for the INDIVIDUAL mode.
Thoughts and any other interpretations?
Integra shifter:
Acura Integra Manual Transmission For 2023 Integra Confirmed by Acura! 1634708747289
2022 Si Shifter:
Acura Integra Manual Transmission For 2023 Integra Confirmed by Acura! 1634708834207
Acura Integra Manual Transmission For 2023 Integra Confirmed by Acura! 1634709208421
TigerEyeJazz
TigerEyeJazz
Integra shifter:
2022 Si Shifter:
It’s the individual mode. All Acuras have an individual mode so they weren’t going to leave that out of the Integra. Only thing is we don’t know which model got it first.
Edit: Individual mode actually saves the preferences you created even after you turn your car off.
RobbJK
Robb
Columbus, OH
2019 Honda Civic EX Coupe
Question about this individual mode... would it also keep the auto stop/start from turning back on if your preset had it turned off?
TigerEyeJazz
TigerEyeJazz
From what I tested yes. Though that’s the current Acura models so not sure if the Integra will get the same style.
TigerEyeJazz
TigerEyeJazz
so this is how the IDS system on current Acura’s work. We all know that the Integra will use a more Civic based system and have buttons and switches for its mode selector.
