Product Update - PRL Motorsports WiFi Ethanol Content Analyzer / Flex Fuel Kit
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
2017 Civic Si, 2016 Civic EX-T, 2018 Type R
The NEW PRL Motorsports Plug ‘n Play WiFi Flex-Fuel / Ethanol Content Analyzer Kit allows customers to wirelessly monitor ethanol content via any smart device or enable flex fuel via an optional 0.5-4.5V configurable output with a tuning device. Our innovative Patent Pending design utilizes the factory fuel line, which eliminates the chance for alternative fuel line deterioration and improves aesthetics. This kit utilizes factory plugs/outputs under the hood for power and communication to the ECU, meaning no need for additional wiring, cutting, splicing or running wires to the fuse box or through the firewall into the cabin! All hardware and bracketry is include for quick and easy installation. Kits can be installed and uninstalled within minutes. Please note that our kit does NOT utilize an ethanol content gauge, as we feel that this is unnecessary. Hondata and KTuner V1.2 both offer Bluetooth capabilities, while the KTuner V2 LCD screen can be used to display ethanol content if desired. All components are ethanol compliant!
Now Available: https://prlmotorsports.com/products...zer-flex-fuel-kit?_pos=6&_sid=cfa2537c5&_ss=r
Acura Integra Product Update - PRL Motorsports WiFi Ethanol Content Analyzer / Flex Fuel Kit PRL_FlexFuel-1
Acura Integra Product Update - PRL Motorsports WiFi Ethanol Content Analyzer / Flex Fuel Kit PRL_FlexFuel-5
What is Flex Fuel?
  • In a nutshell, “flex-fuel” allows an internal combustion engine to flexibly utilize one or more different fuels (usually gasoline blended with either ethanol or methanol fuel), and both fuels are stored in the same common fuel tank. Flex-Fuel systems utilize an ethanol content analyzer to determine the amount of ethanol in a fuel system and a converter to send this reading to the vehicle’s ECU to instantaneously adjust for varying fuel mixtures.
Why Run Ethanol?
  • Due to rising gas prices and the push for alternative fuel sources, ethanol, derived primarily from corn, has become a common, cost-effective fuel choice. Ethanol has now found its way into most modern gas stations and the community now understands its list of benefits in comparison to gasoline, such as the fact ethanol burns cleaner, cooler and is more resistant to detonation. Because of these characteristics, ethanol is a cheap alternative to expensive race fuels like race gas and/or methanol, especially with high(er) compression factory turbocharged vehicles.
  • E85 = 85% Ethanol and 15% Gasoline whereas E30 = 30% Ethanol and 70% Gasoline and so-on.
RB2490
new york
I really want to try flexfuel on this platform. Had it on my frs and it definitely made a difference in power and tq. Only downside was mpg vs 93 octane. If you need another tester let me know😉
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
It makes a HUGE difference with these cars, especially with the ability to add more boost and timing. For reference, our shop Integra gets about 30 MPG on flex fuel at this time.
ALSO, there seems to be some confusion or misunderstanding regarding the factory fuel line assembly within the community. Did you know that the factory fuel line assembly is actually Teflon and extremely resistant to ethanol-base fuels?
Acura Integra Product Update - PRL Motorsports WiFi Ethanol Content Analyzer / Flex Fuel Kit 6467_634846761694708_4609129631012668941_n_480x480
The factory fuel line is actually constructed with an EPDM (fuel and oil resistant synthetic rubber) outer hose and inner ETFE (another Teflon coating that is similar to PTFE) liner, which offers great resistance to a variety of fuels, including ethanol-based fuels. Because of this, there is no reason to "upgrade" or replace the factory fuel line assembly when used with this Ethanol Content Analyzer / Flex Fuel Kit unless kinked or damaged (please note the "Do Not Kink" Warning located on the line).
RB2490
new york
That's actually good in terms of mpg. When I was running e85 in my frs mpg went from 30-31(93octane) to about 21-23. I'm going to consider going flexfuel in the teggy since I have at least 8 to 9 stations around me that carry e85.
So basically your saying it's safe to run full e85 vs people saying e30? That's the only reason I've been apprehensive. I rather e65-85 vs having to worry about mix to get e30
