albundy
Al
Toyota
I had a similar issue for a bit. I can’t recall exactly what I did, but I think I just updated my PW and it all worked after that. Still works with LiveKey.
Could you confirm that it is still working for you? Also, did you change the password this week? I thought it is an API change that caused the issue. Thanks
As of yesterday (and for the past month or so) it’s been working perfectly. I just tried, and it’s not. Says “not possible.” <Sigh>
albundy
Al
Toyota
Thank you for the confirmation. I believe there was change in the late afternoon yesterday which rendered the invalid credential message. MyQ must have blocked LiveKey from logging in. Hopefully, this integration will be working again.
Now that I think about it, I did an iPhone update late yesterday. I’ve been doing Beta updates throughout the past several weeks. I wonder if that has something to do with it.
albundy
Al
Toyota
Nope, it doesn’t have anything to do with it.
vbmike73
OH
Jeep
So I tried again today to add MyQ to LiveKey and Simple Commands. I was successfully able to log into both. It appears to be working again now. Hopefully others will have success as well.
SCalmy
Steve
Las Vegas
Honda Ridgeline
Thank you for this. I was able to get this to finally work. The only thing is that I had to connect to myQ through the iPhone app, I couldn't do it through the Mac app. Once connected through the iPhone app, I was able to use it on both.
Update: Sep 10, 2023. It no longer works and getting the invalid credentials error.
DocMarty
Martin
Subaru
I have tried this and get the message from Siri "OK done...not possible to execute the command requested". I am using the correct wording Hey Siri open garage door) for the command and using LiveKey and the Shortcut app as detailed above. I would really appreciate any suggestions.
Did it let you log into LiveKey? I’ve been having trouble getting back in lately.
It’s either that or you need to make sure Step 8 matches the top of the second screenshot.
DocMarty
Martin
Subaru
I can get into LiveKey. The screen shows in the Items line "Garage Door" not Garage Door Opener but everything else is the same.
Honestly, LiveKey is great when it works. However, it tends to not work enough times to make this a bit unreliable. I’m leaning towards getting a Meross that someone suggested.
Just get a Meross and be done with it. MyQ if frustrating to use.
Which model Merooss did you get?
From what I’ve seen, the close command closes the garage immediately without the 10 second delay with lights flashing. Is that correct?
albundy
Al
Toyota
Could you please confirm the MyQ integration still work? It still doesn’t work for me and it spit out “invalid credential” as an error message.
vbmike73
OH
Jeep
It still works for me. I just tried it right now. Couple questions...
1) Are you using Simple Commands or LiveKey?
2) I'm assuming you are getting the error after you've logged into the app, when you're trying to add the integration, correct?
3) Have you verified that you can log out of the MyQ app and log back in with those same credentials?
FYI, LiveKey is working for me now. Previously, it wasn’t taking my MyQ info. I thought I had previously done this, but I tried to logout and log back into LiveKey, and now it connected to MyQ.
