Engine Bay Rattle
lnf
Grant
Wisconsin
Lunar Silver, 6MT Integra
Hey all!
I received my Integra 6MT this past Monday and have been loving it! I notice when decelerating, there's a rattling sound that almost sounds like a clutch throwout bearing going bad. When pushing in the clutch, it seems to subdue the noise as well.
Has anyone experienced an issue like this yet?
Acura Integra Engine Bay Rattle IMG_2127
Sounds new to me. See if you can capture the sound and conditions in a video.
Tony503
WA
If there’s a rattle when the clutch is engaged (ie. pedal up, whether it’s in gear or neutral) and it goes away when you push down on the clutch pedal, it’s likely the input shaft bearing going bad. Would not expect that on a brand new car, so likely a factory defect. I’d take it to Acura ASAP and drive it as little as possible because if that bearing falls apart, you’ll probably need a new MT.
  • Like
Reactions: lnf
ItsGizzman
Earth
2023 Integra 6MT, 2004 MX-5 Miata
Is it a super high pitched buzz/jingle/whine? I’ve noticed the ā€˜23 Integra has the same turbo wastegate sound that the FK8 CTR and 11th gen Si have (and apparently some Accords).
Basically when you have the windows down and are decelerating you can sometimes hear a faint rattle/whine/metallic jingle. It’s normal but annoying.
lnf
lnf
Grant
Wisconsin
Trying to work with my dealership to get it in. They have told me, ā€œit’s going to take some time, due to the holiday.ā€
lnf
lnf
Grant
Wisconsin
Is it a super high pitched buzz/jingle/ whine? I’ve noticed the ā€˜23 Integra has the same turbo wastegate sound that the FK8 CTR and 11th gen Si have (and apparently some accords).
Metallic jingle sounds about right. Sounds just like a metal washer under a nut vibrating and rattling.
lnf
lnf
Grant
Wisconsin
Just did some research and found a couple of videos. Yup, it’s definitely the noise. I still need to take it in due to some issues with parking sensors, maybe they’ll have some sort of workaround… but doesn’t look too promising.
ItsGizzman
Earth
Yeah you can see in some of those past discussions people have tried a few things. I guess it's just something we'll have to sort of get used to with modern Honda turbos.
Either way, that's likely all that is. Bummer you're having an issue with sensors.
