Front & Rear Dashcam with battery pack
debianx
Carlos
Charlotte, NC
2024 ABP ITS, 2006 Toyota 4Runner
So I'll be installing a 2ch VIOFO A229 plus dashcam and Powercell Dash Cam Battery Pack into my ITS soon, still need to gather some parts. Blackboxmycar.com recently did an install into a 24 ITS and in their video they recommended to use either a 20 or 30 amp fuse with an add-a-fuse adapter. Here's a link to their YouTube video:
Looking at the fuse diagram in the car and at fuses themselves, I noticed that I have a 20 amp fuse installed in slot 16 which for a sunroof that our cars don't have. I know if we had a sunroof, it would only work while the car is turned on, so in essence I should be able to use this fuse for hardwiring the battery pack. Anyone see any reason why this would not be case?
Acura Integra Front & Rear Dashcam with battery pack PXL_20240919_203320846
Acura Integra Front & Rear Dashcam with battery pack PXL_20240919_205759416
Acura Integra Front & Rear Dashcam with battery pack PXL_20240919_205834470
RamVA
McLean, VA
Can you just test it with a volt-meter?
It might be helpful to look at the wiring harness/coupling for the sunroof cars and compare it to yours. Then you can figure out where you would have to wire it in.
lumper
2007 Nissan 350z
grab a multimeter and test to see if you have current when the ignition is off or not.
I am about to do the same install for the A329 with a power4cell 8 and an ssd.
I have never done one though so I am a little intimidated by all of it.
Did you get yours done?I ordered the 329 with a 4tb ssd, a 512 sd card and a powercell 8 battery pack, plus the hk4 hardwire kit,. and some other accessories too.
lumper
2007 Nissan 350z
Did you pop off the plastic right under the steering wheel where the fuses are listed as shown or was it behind a different panel?
Er34er34
GTA
Fuses are just exposed, to the left of the steering, with the OBD port.
Er34er34
GTA
How did your install go in the end?
I'm curious about the 20-30A fuse suggestion. These cams don't use anything near that level of current. The adapter that comes with the Viofo only puts out 5V 2.4A max(12W). Obviously 20A fuse will make it work but you are effectively bypassing the point of a fuse in case something goes wrong.
