Integra Type S driving Styles with Breakin Period
Just did my first couple of real pills in the car, only going to 6.5k rpm as the max for now, but damn! This thing is quick! I’ve only done a max of 75% max throttle and the car just gets up and goes no hesitation. I plan on taking this to the dragon next week and now it’s got me worried I’m gonna be going too fast! The pull I did onto the highway was similar to an m4 cs I drove where you just get in boost and start rocketing forward. I love it!
I'm with you on that one - this car feels plenty quick for me.
I guess my previous cars were all just slow and having a truck as a DD the last few years certainly didn't help. I'm sure folks here that have had porsches, M4s etc would think otherwise but I haven't truly been able to stretch its legs because the car picks up speed quick enough that it just doesn't feel safe on public roads.
STi from DSM
Minnesota
www.youtube.com
Break in periods vary on lots of different models. BMW requires a 1200 mile break in service. If you don't do it you void your warranty.
Acura is not that way. If people want to change oil at 1k miles... be my guest, lol. Unnecessary interval in my opinion, but I do not pay for your vehicle.
I will follow the manufacturer recommendations as I am lazy and don't change it myself anymore. I think I remember seeing that the first oil change is free? I have been spoiled with Audi Care and BMW prepaid maintenance and usually get rid of my cars before that period is over so everything has been essentially free for the most part. It will be a change coming to Acura. I'm excited for it though.
I plan on breaking mine in for about 500-600 miles. I have done 1000 miles and let's be honest even 50 miles is hard to do. People are right though that these cars are driven hard at the factory during their burn in testing they do for every vehicle. But hard testing for 5 miles is different than hard driving for hundreds of miles. I plan to keep it at a reasonable RPM for the first 500 - 600 miles and then start increasing from that.
Jolman
Joel
Pittsburgh
25 Integra Type S
For years now cars come from the factory broken in. I don't get crazy until 500 or so miles to seat the brakes. No more break in oil like in the old days when i started to drive.
Engines are not broken at the factory. They are checked for function and leaks. Do you think factories have the time to break in hundreds if not thousands of engines?
ashmostro
Northern VA
Adding to the thread for perpetuity.
Changed my factory fill out to Motul 0W-30 at 750 miles. Will do another change at 2k, then will do 3k OCI's moving forward with the benefit of FCPEuro's lifetime replacement program.
Gremlin85
John
2025 Acura ITS
I kept mine under 5k Revs and 50% throttle for the first 600 miles. I changed the oil and filter at 1000 miles with Pennzoil Ultra Platinum and then again at 3000 miles with Amsoil OE. I am waiting for the 1 free oil change at the dealer and will continue to change my own oil at 3000 mile intervals.
I had excellent success with my last new vehicle this way. It was a 2013 F150 Ecoboost, and if you know how temperamental those engines are with maintenance, then you know. I had zero timing system issues (common for the VVT solenoids to go and timing chain "stretch" is common). I got rid of it at 90k miles. Before so, I was changing spark plugs and borescoped the cylinders, valves, and timing chain which looked excellent. Valves had minimal carbon, but I also had a catch can.
I don't beat on it, but I do drive it spiritedly from time to time. I enjoy this car very much. I will spare no expense on 3000 mile oil changes.
whtciv2k
DE5 Integra Type S
I didn’t redline it every gear, but I gradually took it up to 5-6k a few times every drive. At 600 miles, did my first oil change and then sent it.​
elh0102
Ed
I just had my first oil change at 3,100 miles as the computer suggested. It was showing 15%. The tire tread measured about 7/32", pretty consistent on all four. That would suggest a tire life of around 10-12K miles. I don't abuse the car, but I expect a larger than average portion of my miles is under enthusiastic conditions. I'm retired and the car sits in the garage until I feel like driving, which generally means that I feel like some spirited driving. Just wondering if my experience with oil and tires is generally similar to others who drive in a comparable manner.
mek
Mekkham
San Diego
2026 Acura Integra Type-S
Just hit 600 miles and ive notice my clutch feels soft. Ever since I got the car its been raining and cold. But recently the its been getting warm. Anyone notice a change in clutch feel depending on the temperature?
Have never driven my Integra in temps less than 45F degrees, however my Civic with a near identical 6 speed changes drastically with temperature. When the temps are 0F or lower the pedal is very noticeably delayed until it's fully warmed up. So much so I need to adapt my clutch control.
Dead of summer to peak winter there is definitely a noticeable difference however one day to the next with similar temps, something else is wrong if you feel a difference.
What is the temperature swing that made you notice?
mek
Mekkham
San Diego
I would say a 10 degree difference. The only thing ive done is install the PRL intake. I guess my concern is hopefully I didnt mess up the clutch. The "bite" point is a bit higher now. Before I barely let go of the clutch and give it a little gas and go. Now I have to give it more gas before letting go of the clutch.
ashmostro
Northern VA
I have experienced zero difference in clutch feel/bite point in temps ranging from 15 degrees to 90 degrees F.
10 degrees Fahrenheit should not make a difference and like I mentioned, the effect in extreme cold weather would disappear once the car is warm, it's not permanent. Also in this case the bite point is technically the same but it's the cold fluid that drains slower, so if you are fast on the clutch it'll be higher in the range before it engages. Think clutch delay valve on steroids.
All said, it sounds like it might be something. else.
mek
Mekkham
San Diego
Not sure what else it could be. Like I said the only new addition is the intake.
Clutch and brakes share a master so if you foul your fluid you could feel it.
The bite point always moves down closer to the floor when the clutch wears, the fluid fades, the fluid boils, it's too low, etc. It almost never moves up.
Your intake could be messing with your throttle application if you missed a hose or pinched one putting it on. Check your install.
