It does cut the console storageTbh cutting that hole doesn't seem too bad, unless it cuts into the actual center console storage.
Oh, yeah... No. Will also be eagerly awaiting the results of the CTR box fitIt does cut the console storage
Keep us update. I hope the ctr box will fit.It does cut the console storage
Waiting on the FL5 storage box to Arrive..Keep us update. I hope the ctr box will fit.
@Interga23Waiting on the FL5 storage box to Arrive..
Yes it did. I think I updated my main post but I will check. Only issue is the armrest frame is slightly different and only bolts up with 2 of the 4 screws and not fully aligned with the track that does the soft opening/closing feature. You need to order the console and steel bracket that goes under it. Duct fits perfect with no cutting. FL5 armrest would be a better match and you can then swap the top cover between them.@Interga23
Any update on the install? Did the FL5 console work?
Since we're on the topic, what how would you rate the difficulty of this endeavor and how long did it take? I honestly hate prying clips for fear I'll bust them, warp plastic, etc., but I believe it can be done with sufficient time and patience.Yes it did. I think I updated my main post but I will check.
Took Maybe an hour. Difficult part was doing it in 90 degree weather outside. Everything else either screws or snaps together so really easy.Since we're on the topic, what how would you rate the difficulty of this endeavor and how long did it take? I honestly hate prying clips for fear I'll bust them, warp plastic, etc., but I believe it can be done with sufficient time and patience.
Having had it for a few weeks now, would you say it was worth doing?
Wow! A one-hour install says a lot--especially since it sounds like DE5 install is a little tougher than FL5 install. It's crazy to think they're different, but it doesn't surprise me at this point.Took Maybe an hour. Difficult part was doing it in 90 degree weather outside. Everything else either screws or snaps together so really easy.
Like I said it's 6 or so screws and snap some trim pieces off. Pretty darn quick.Wow! A one-hour install says a lot--especially since it sounds like DE5 install is a little tougher than FL5 install. It's crazy to think they're different, but it doesn't surprise me at this point.
And since we’re on the topic of ripping things apart… how tough is it to get the door panels off/back on? I ordered pattern projectors from Europe but I’ve been hesitant to start the install process.Like I said it's 6 or so screws and snap some trim pieces off. Pretty darn quick.
Pretty quick. One screw by the door handle area. Actually I think it might be under the switch controls. Then just pull starting from the bottom of the door panel and unplug connections for speakers and such.And since we’re on the topic of ripping things apart… how tough is it to get the door panels off/back on? I ordered pattern projectors from Europe but I’ve been hesitant to start the install process.
