Sirimoto cmc damper delete and stainless steel clutch line.
LyonIV
Christian
2024 Acura Integra Aspec
This weekend I installed the Sirimoto cmc damper delete and Sirimoto stainless steel clutch line. I spent $150 for both.
I got it because I felt shifting in lower gears was very slow and inconsistent (especially from 1 to 2). I also wanted a heavier clutch feel because I felt like the clutch is too light.
Acura Integra Sirimoto cmc damper delete and stainless steel clutch line. 1000003626
Acura Integra Sirimoto cmc damper delete and stainless steel clutch line. 1000003627
Acura Integra Sirimoto cmc damper delete and stainless steel clutch line. 1000003625
After install: noticeable difference shifting from 1 to 2. The bite point is more consistent and firmer. The clutch pedal feels the same, weight wise.
Would I recommend it? If you feel like shifting from 1-2-3 is to slow, yes get it. If it doesnt bother you, dont bother.
Which one made a bigger difference? Im not too sure since they were installed at the same time.
You should also remove your delay valve in the slave cylinder.
