Phdintheory
- First Name
- Rick
- Joined
- Dec 7, 2022
- Threads
- 1
- Messages
- 3
- Reaction score
- 0
- Location
- Long Beach, WA USA
- Car(s)
- 1991 Integra
- Thread starter
- #1
Okay, I've got a '91 with 285,556 miles. It's been running real loud with what appeared to be a dead cylinder.
I had determined it was a valve problem so I decided I'd give adjusting them a try. I've never done valves before so I read up on it until I figured I had a general understanding of what to do. That is until I started in...
First problem I had was trying to understand how you're supposed to be TDC one cylinder, but only if overlap is happening on another then you adjust the ones you...?
So what I figured is I'd just watch the cam lobes and when a set of them were pointing straight up I'd adjust them. Then move on to the next. By doing this it would give me a set of intake valves and a set of exhaust valves to adjust. I'd then go on to the next ones.
Got it all back together and now it's not running so hot. It's quieter which is good, but I've lost power and low end torque. Any ideas on what I've done wrong and what I can do to fix it?
Thank you
Thank you
