Integra specific Eibach Pro Kit lowering springs
arod19863
Abram
Acura Integra 2023 Liquid Carbon
And you even got the specific integra part number and not the civic or civic si lowering springs ? I think I’m just going to bite the bullet and order em and I’ll post alignment sheet after springs are done.
Yes I got the specific one for the integra just waiting for my tires to take it to the shop its advertised as $311 that is the one that I got
Ap2Iven
Honda s2000 / 10th Gen Civic
Just got my springs and I’m going to do them the following week. Is there anything I should know to do before I complete this job? Are we cutting or trimming the bump stops? Or is this a straight forward R&R type of repair? .
1. Throw out lowering springs
2. Buy coilovers
I kid.
No don't trim the bump stops. Watch for any binding on the top hats, however. I don't know if this is a current problem, but it was a problem when I put springs on a Honda product. Better safe than sorry.
Ap2Iven
2. Buy coilovers
I kid.
Thank you ! Lol and this car gets springs because my s2000 already has coils and that car is the track car. I want this vehicle to look decent while being my daily.
Dannyboi
Danny
2024 Acura Integra
Yes. I installed SPC camber arms to rear.
i recently installed these springs and I'm getting squeaky noises when going over bumps, turning etc. are you having these problems as well?
I have pro kit springs, no noises. Also have the rear sway, that did squeak a bit at first but once all the lube made it around the bar it got quiet too. Hate to say it but maybve check everything is installed correctly and the bolts are torqued to the right spec. I know I originally had all mine "good and tight" then I found torque specs and everything was too tight. Not sure if that will help.
Which sway, RV6? I still have to install mine. I was thinking of doing the rigid collars at the same time since I’ve had them for months. Then probably adding the Pro Kit as well while in there as long as my wide setup will fit. Otherwise I’ll have to figure out camber parts or wait & go with RS-R/Ohlins maybe.
eibach rear sway. if you don't have poke with your setup now, you should be good, right?
I’m not exactly sure yet, but I think it’s mainly for grip & even tire wear. I know if I go one size up to 285 that Apex wheels said that camber is required.
