- First Name
- Gordan
- Joined
- Jul 9, 2024
- Threads
- 8
- Messages
- 735
- Reaction score
- 455
- Location
- Kansas City
- Car(s)
- Integra type s
It's much more complex than, "will it void my warranty". The short answer is yes... The long answer is it depends on your dealer and how well they want to work with you if something were to come up. Engine problems could easily be blamed on tune, but by law they have to prove it's the tune that did it. Still, there are cases of dealers simply refusing to work on tuned cars or saying they won't touch engine with warranty when tuned. There's also the ethical side of choosing a tuner that has 50 state certification or not, but that's a personal ethical thing not a technical limitation. And again, reducing Rev hang impacts the initial bit of deceleration when you let out the clutch. Once the clutch is totally out the throttle plate should be closed.I just checked and my Rev match is already turned off.
It’s kind of disappointing going down a hill and there’s very little engine brake.
What do I need to tune the car?
Well that void my warranty?
thanks
There's also the gearing to keep in mind. The gearing on this car is intentionally very short and the transmission is designed to have low drag/loss. You won't get as hard of engine braking on any modern car as you will much older cars with heavier flywheel, heavier trans oil, weightier gears, and taller gears.
