Newb and learning ..diverter valve ? Bov ? Want more sound
Nivek2slick
Nivek2slick
Kevin
La habra ca
Acura Integra type s
Yes that will be fine. They will have an adapter option to connect either the factory or PRL inlets to their new airbox for those 2 setup options for people.
Nice thanks bro much appreciated
Came across this vid a while ago, the "custom" elements aren't really all that excruciating. This could still very much be a DIY-able solution according to this video at least.
wdrx02
Batman
Integra Aspec w/Tech CVT
Is there a 2023-2024 integra specific application for purchase now?
It sounds like a PRL intake and a HKS BOV is a nice combo for a oem replacment. Anyone find a video or link that would show the install or configuration? (Just wondering).
ZeroGSR
2024 Integra Type S (LCM)
https://gtchannel.com/video/1326/hk...off-valve-for-honda-civic-type-r-fk8-install/
That has the install instructions, note they do NOT have a FL5 kit yet and this requires replacement of one of the charge pipes. The FL5 charge pipes are larger so it's not a direct swap. Someone HAS done it though on the Civic Forums so it does work but you have to rig it a bit (and you lose ID).
Then you need any intake with a silicone adapter, doesn't have to be a full replacement, you just need that piece to port into as shown in Optronix's video.
Nivek2slick
Nivek2slick
Kevin
La habra ca
Only if someone just knew how to do it locally it's like shut up and take my money lol
wdrx02
Batman
Thank you for the share! Without having to rig I will wait for a specific charge pipe for our Integra. However if this looks promising to do the same Bolton for our OEM intake swap + a HKS bov.
wdrx02
Batman
Although what the aspec (non-type s) our outer diameter of the stock intake? Looking at HKS POV Universal kit. I am wondering if it's worth a try
Hks universal kit
Looking at PTL HVI: PRL HVI
ZeroGSR
Hks universal kit
Unless the process has changed in the last... 20 or so years, those universal kits are just a flange, you then have to weld it to your OEM charge pipe and cut a hole in it. You could always buy a spare and have a shop fab it up for you, that way you can return it to stock later if you need to. Just make sure you have the vertical clearance for the BOV where you want it placed on the pipe.
