- First Name
- Gordan
- Joined
- Jul 9, 2024
- Threads
- 11
- Messages
- 1,332
- Reaction score
- 899
- Location
- Kansas City
- Car(s)
- Integra type s
Don't want to get too deep into it, but I've done some of my own testing in various vehicles and regular refill rates with cars that see oil temps of 275F+ in track use. Amsoil has stayed fairly stable and avoided shear even up to 325 to 350F spikes. Other oils haven't been as lucky in my use cases, but certainly others are also high quality. In fact, I actually prefer a liquimoly 5w40 or 10w60 for certain German car applications over amsoil, but I certainly wouldn't turn down the amsoil 0w40 euro formula, which does contain more moly than their other blends. Ime it's more important to ensure you have a fresh oil than a specific brand.Um, tested by who? Amsoil?Not knocking them as their Signature Series (SS) is likely what you are referring to as its their premium product, and excellent: but for the money other small blenders have arguably better products depending on what you intend to use the oil for (long drains, shear stable, low/no VII etc...)
The factory fill appears to be Type 2.0 oil which has a lot of moly in it, and not available retail in the US. The Honda/Acura Full Syn here is made by P66 and is meh. Both VOA of the Type 2.0 and samples of the factory show near identical data.
Odd how the EU manual (CTR, but identical K20C engine) *specifies* Type 2.0 it to be used, or 5/30 instead. Why different US? HmmmIts unfortunate we don't get that here in the US, would be a good oil to use if Honda feels they need to put that in the EU manuals
If you Google around for "amsoil vs... Oil analysis" you'll get a lot of results. It's often at the very top tier and from what I've seen it normally edges out to number 1. Then again, pennzoil is usually up there in the 1 or 2 spot, and the last few years liquimoly has gotten more popular.
You're right the factory fill contained very high moly content. It's very low on mag though. The replacement oil from the dealer is the exact opposite. I'm. Really not a fan of the virgin oil's formulation from a high level. I curious how it's used values will look and how it will have degraded. Notice in my linked analysis how much viscosity the factory fill lost after one track day. I suspect it was a 0w20 to start.
From my personal past experiences, I would not run royal purple or Mobil 1 again. Out of all the oils I've used those are the only two brands where I consistently found the journal bearing in my old sti weeping oil. Switched to rotella t6 on it and no more weeping. Oil analysis on them also showed ridiculous shear and reduction in viscosity. I've seen people run them in mustangs and boosted vettes for years without issue, but for some reason they hated my subaru.
It all depends in the end, and metal compositions of each engine are going to be different... That's why the oil analysis is crucial.
