Which Acuity parts needed to just remove lateral slop on shifter?
Spart
The OEM boot is indeed designed with some forward lean to it, that's probably why you're having issues with the odd gears. If you reverse it you'll have issues with the even gears.
It seems like the taper actually goes the wrong direction. There's plenty of slack in the even gears and no slack at all in the odd ones. I wonder if flipping it around will even it out.
Ordered a gallon of this last night:
Acura Integra Which Acuity parts needed to just remove lateral slop on shifter? 1768223917689-hf
I am happy with the performance of the OEM Honda fluid in cold weather. I've also been really happy with Redline MT-90 in cold weather (in my truck) so I'm going to give MTL a shot. If I don't like it, ACDelco Synchromesh FM will be next up.
I also got the Acuity bushings to do "while I'm in there."
Ash @ S2i Audio
Ash @ S2i Audio
CivicX Basic Sponsor
Ash
Northern VA
www.s2iaudio.com
I am running MTL and like it a lot. In the summer I plan to swap it out to MT85 (and go back to MTL next winter). Two flushes a year might be overkill, but at least the trans won't fail from under-maintenance :)
Spart
I mean it's not necessarily overkill if you're tracking it.
If you aren't tracking the car, I'd probably just run one weight all year long and extend that interval.
itsgr8
SF Bay Area - Mid-Pen
Just fully caught up on this thread. We almost went through the same journey regarding shift upgrade! Thanks for sharing the experience. I also had the hybrid racing detent spring and didn't like it. I came across this fk8td detent spring, and a blog post about installation. It makes more sense to me in terms increasing the gear engagement feel. I can report back once they arrive and installed
itsgr8
https://fk8td.com/product/fk8td-detent-springs/
https://functiontheory.com/2024/01/detent-springs-fk8/
Spart
I am also intrigued, but I will say I'm a little put off by that guy and his website.
He specifically says to not follow the Hybrid Racing instructions, but he doesn't really provide any alternative instructions for his kit?
Closest I could find is this:
...which just seems like a rant and not helpful instructions.
Also, if you browse the "DE5" section of his website, you'll see this part listed for the DE5:
https://fk8td.com/product/fk8-fl5-clutch-master-upgrade/
That is definitely not something you'd want to try installing in the DE5, as the FL5 and FK8 have completely different clutch master cylinders. What you see there is a FK8 clutch master with the integrated CMC damper. The FL5 and our cars have a different clutch master cylinder design with no integrated CMC damper. What they have instead it is a traditional clutch master cylinder and a separate (and easily removed!) CMC damper component under the battery between the CMC and the slave cylinder.
He also lists this for the DE5:
https://fk8td.com/product/fk8-fl5-clutch-slave-upgrade/
Again that is an FK8 specific part. The Honda part number for the FL5/DE5 is different. I believe the fitting for the hydraulic line is different - I haven't compared them personally so I can't 100% say for sure, but they are certainly visually different.
So that doesn't inspire confidence that his detent spring mod works the same way on the FL5/DE5 as it does on the FK8. These are really obvious generational differences that the guy is getting wrong.
itsgr8
I found the fk8td detent springs via this blog post:
It's for FK8. I assumed there's not much difference between FK8 and FL5 in terms of the transmission detent mechanism (maybe I'm wrong).
I actually did installed hybrid racing spring previously, and similar to @ashmostro, I really didn't like how it made shifting so difficult (subjective, I know). So I ended up removing them.
After reading the blog post above, it did make sense to me: there are 3 shift selector forks and rods internally, so it makes sense that we need to replace 3 detent springs, one for each. I don't know how can hybrid racing achieve that with only 1 spring (aside from the swing arm detent spring).
I also browsed the fk8td youtube videos and looks like this guy does fk8 engine builds/tuning for a living -- nerdy, but seems he really knows what he's talking about. So I decided it give it a try.
itsgr8
regarding the "upgraded" master/slave cylinder, yeah I do agree they're a bit sketchy. No plans to get them :)
I already installed the JSR CDV delete slave cylinder, don't plan to remove the damper on master cylinder yet.
Spart
Right but he's obviously completely misinformed about the FL5/DE5 clutch hydraulic system, so what else is he getting wrong?
Spart
You should remove the damper because it causes more delay than the actual delay valve. Doesn't seem to do much of anything for NVH.
itsgr8
Really? good to know, I tried so many things already trying to getting rid of the infamious 2nd gear grind (CDV delete, master cylinder rod, clutch pedal adjustment, transmission fluid..), and I've lost hope, now I just wait a full second (if not more) between 1-2 shifts..
Now you've given me some hope :) I'll give the damper delete a try!
Is this the one to get?
https://www.sirimoto.com/p/mm/honda...ch-master-cylinder-cmc-damper-delete-kit.html
Spart
That's the one I used, with the caveat that you should point the loop forwards (away from the driver) rather than towards the driver as the instructions suggest, in order to maintain clearance for a wire harness that passes behind the CMC damper bracket.
Also, and I cannot overstate this enough, set yourself up for success to have a perfectly bled clutch hydraulic system. Vacuum bleeders are not it. Get a pressure/power bleeder.
My instructions/etc for all of this are here: https://www.integraforums.com/forum...t-1-10th-second-of-lag-delay-per-shift.59333/
itsgr8
Thanks for the suggestion on bleeder. I have a pressure bleeder (manual pump) but am having a hard time finding an adapter cap that fit the DE5 brake fluid reservoir. Do you have suggestions?
Two ways you can do it quickly.
Buy a universal Honda cap with adapter and thread on the fitting you need.
Buy another oem cap, drill a hole, and epoxy on a fitting.
I went the former route. Some cheapo Amazon universal. Works fine, but it's a bit too snug so I have to lube up the gaskets before use.
