Seems like the Type S accessories have the same part number as the normal but an A at the end..
Door sills for type S 08E12-3S5-200A
$325 online
ZeroGSR
2024 Integra Type S (LCM)
Anyone know the PN for the black Type S badges? Think I have everything else I need!
As a note for others looking for parts, I looked up the A Spec parts and then if there is no letter, add an A (as per above), otherwise increase it one letter and that mostly works.
wtam1100
Columbus
CTR
Any one happen to have the part number and install instructions to the heated steering wheel? Don't need it till winter time but would like to see if I can find the part somewhere else cheaper.
L___I
U.S.
M440 GC
I believe the black type s badges are #08F20-TYB-200A. Any chance you know what the front and rear black A emblem part numbers are?
L___I
U.S.
M440 GC
I was looking for the type s heated steering but could not find it. On the A spec, there is a separate part number for the auto vs manual for some reason, so adding the "A" to the end of the part number doesn't work here.
Rdrcr
WA
The heated steering wheel does come up on the Build/Price for the Type S. $475
ZeroGSR
Thanks, I think those are for the MDX, the TLX has a different PN also 08F20-TGZ-200 so assume the INT will have it's own?
As for the Acura badges, I assumed they were the same as A Spec but maybe the front one isn't. I am having my front installed by dealer, so only buying the rear for now.
08F20-3S5-200
08F20-3S5-200A
L___I
U.S.
M440 GC
Sweet, let us know if you find a part number. My dealer is asking $775 for it installed. Not sure if this is worth
08F20-3S5-200
08F20-3S5-200A
For the Type S badges, that’s the part number listed in the Integra Type S install guide from the original post of this thread. It does say MDX on the online stores, but I was assuming it wouldn’t be any different. What makes the TLX ones different?
I’m going to have the dealer do the front A as well since it requires taking the bumper off. They quoted me $170 installed which seems okay, but I wanted to see how cheap just the part was too.
I guess the back emblem probably is the same for all integras. Can’t see how it would be different now that I’m looking at it.
ZeroGSR
I don't know if the TLX ones are physically different, just know they have their own part number. But will take a chance with the MDX thanks! I need those fender ones for PPF install. $170 seems quite reasonable for dealer rates and definitely worth me not messing up the front bumper... For the back, just check the forums to see if you prefer it color matched, that's what I am doing, pulling the vinyl on the backing before install, which I assumed I couldn't get the dealer to do.
Gregg
Gregg
Charlotte, NC
I'm fairly certain the part# is 08U97-3S5-210A. and the installation doc is here: http://www.urvi.net/forumfiles/SB/BII19600-23.PDF
Just a quick note that you can find install docs as they come available at AcuraZine.com
https://acurazine.com/forums/integr...s-accessory-installation-instructions-999245/
