I signed up with actually very little advance lead time (~3 weeks) for an SCCA Track Night in America, this one at Dominion Raceway in Thornburg, VA. The turnout felt small compared to what I'm used to but apparently was large relative to this particular event/track according to the staff. It was great for me. I ran in the novice group, and as I'll get into I pretty much surely should have been running in the intermediate group, but it was a great event, great people, overall fantastic time and I can't recommend it enough, especially for anyone who maybe has done an HPDE or two with some in-car instruction before and wants a taste of that next step in HPDE when you're on your own.
Let me be blunt: this car is amazing on track. I've been on this track in a 911 and can say sincerely that I had just as if not more fun in my Acura than I did piloting a 991.2 C4S PDK around this same track. And felt just as confident! Which is a feat on its own- both from a "feel comfortable going fast" perspective, as well as a "wear and tear on the car" perspective. Worth noting, 2 track days I previously ran in got cut short due to issues with my cars; a 2015 STI that I had just had quite a few aftermarket parts installed and tune done on started leaning out enough to make me nervous, and a 2015 M4 cooked the brakes to the point where they shuddered horribly and had to be replaced under warranty.
I did only run 2 20 minute sessions (not counting the "paced laps" where everyone was going ~6/10th or less), but brakes held up great, tires held up great, and no temp issues. I left before the 3rd session because I was tired and they were running behind, not due to any issues with the car whatsoever (the brakes did a bit soft towards the end of the second session but they still stopped the car just fine). I did remember to keep a full tank due to fuel starvation issues people are commonly experiencing with these cars. I somehow managed to burn through half a tank (!) of gas in my 2.25 sessions though, and experienced no such issues.
Again, I ran in the Novice group but almost everyone in the group had about as much experience as me with a handful of track days so it wasn't like I'm some expert out there "pub-stomping n00bs" or anything. But I honestly felt like I was egregiously outpacing everyone and will definitely run in the Intermediate group next time, where I'm sure I'll be humbled. I'm seriously not trying to blow smoke up my ass, but I think it's important to note that someone like me with maybe 3 complete track days and a handful of autocrosses can get behind the wheel of this thing bone stock and obliterate a Novice group with some significantly fast cars (JDM imported 96 FD RX7, LSx-powered FD RX7, GT500, Mach1, at least one boosted miata, etc.) has to mean something.
I was also taking it relatively easy, especially on the brakes. I was a little nervous about tire pressures because I rolled in there after a 2 hour drive in 70 degree weather and my tire temps were at 30 psi and I thought maybe I'd get some sidewall roll-over and almost stepped out to put a few more psi in- but after the first session established everything was fine. Stock pads, stock fluid, so at the end of the long straight heading into turn 1 I definitely was not going 10/10ths- more like 6/10ths on that stretch, 8-10ths everywhere else. There was still a lot of headroom left for both me and the car, and I was still on someone's ass pretty much the entire day and no one kept up with me. Some aftermarket pads, fluid, and 200 treadwear tires and this thing should do quite well.
I fully expect Lewis Hamilton himself to come find me and sign me to Mercedes, so let's move on...
I have really zero true complaints with the car. For my needs, it fulfills 100% of my requirements. But if I were to be slightly more hardcore or nitpick, here are the only issues I think are valid:
- The seats, let's just get that out of the way. They're good but definitely not great. For autocross I'd say they're perfectly adequate, for a true track day they're functional but leave a bit to be desired. The alcantara centers really do wonders here- if they were leather/vinyl I'll admit they 'd be terrible for track use. I didn't find them distractingly bad like some others try to claim them to be, but I'm sure the Type R seats are better. I'm ok with it because for the 362 days or so I won't be at the track per year I find the seats wonderful, but yes for maximum track effort they could be better.
- You HAVE to disable VSA if you plan on driving this car at the track. Or anywhere fun, really. So get acclimated to the pedal dance.
- Speaking of the pedal dance, with VSA disabled you effectively lose the gauge cluster on the right side. I had it set to tire pressure but had to flick the scroll wheel to see it; otherwise the blank screen with the orange VSA light is all you get over there.
- More on the gauge cluster- the Type R's is way better. There is at least a shift light, and the HUD helps a bit but overall it's nowhere near as purposeful for track driving as the Type R. If I were a track rat I'd find this disturbingly inadequate- but I'm not so it doesn't bother me. It's not like it's useless- it's just not as good as the Type R. There are plenty of amazing cars to drive on track that don't have cool progressive rev counter bars and shift lights; a tach is all you really need. But it's worth noting for those who are still on the fence between an ITS and a CTR. If you plan to spend more than 5 or so track days a year, it's worth strongly considering the Type R for the seats and dash alone.
- It does struggle with understeer in some corners. I think my rare combination of luck and laziness actually did this car a favor, because where I left the tire pressure (~34-36 PSI hot) it felt really well balanced but there was one section where I could see cars start to pull away from me through a long "3rd gear corner", and I knew if I tried to go faster it would just start to push, and it's too long of a corner for the cool "lift off oversteer" this thing is so good at to really help much. I'm sure I could dial that out though. The car is BONE STOCK after all, and all tires the same pressures.
Overall INCREDIBLE for a front-drive, $55k car. I can't put into words how much I love this car, and it continues to grow every time I do more stuff with it. More than any other car I've ever owned, I feel 100% confident saying this is a forever car... which is also why I don't want to modify it too much but that's another conversation for another day.
I did manage to snap some mostly unremarkable pics but here they are anyway.
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway 386316680_24721204784137017_3832789384751906637_n
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway 370071753_24721204797470349_4448063895404500162_n
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway 370056279_24721205467470282_7513380203441929374_n
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway 386495538_24721205224136973_8608810409467117730_n
b0nb0n
Anthony
2024 Integra Type S, 1999 Civic, 1997 Celsior
Very thorough write up and story, we appreciate the input! Love hearing great things about the capability of these cars on track in stock form. Look forward to the day I take mine on!
ender_ong
Andrew
East Bay, CA
Awesome write-up @optronix ! It’s a pleasure to see DE5 owners taking to the track/autoX, where the car is more than happy to be! I was also struggling with keeping tire pressure screen up after pedal dance, eventually said screw it and just checked after each session. Good note on fuel starvation, shit is real
ChromaPop
Franklin, TN
Great write up!
MrWeeks81
Arry
Vinton VA
I can truly appreciate this post, I haven't been on here in a while and I randomly get notifications of posts and I'm happy I read it.
I went to VIR in mine Sept 1st for a trackdaze HPDE event 6 total 30 minute sessions . I ran stock pads with high temp fluid and I have mugen mf10 wheels using Falken azenis 615k+ tires. Everything else stock and it is definitely capable. It was hot during the afternoon sessions mid 90's so I noticed the tires getting greasy quicker the brakes held up great though. It was my first track day so I had to let my balls grow up a lil through the weekend my best lap on the full course was 2mibs 30secs l, I rode shotgun in my car with my best friend behind the wheel and he pulled a hot lap of 2 mins 21secs Maybe one day I can make it up that way . The car really is fantastic on the street and on track !
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway received_846084263383651
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway received_227441873629969
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway Screenshot_20230904-203842
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway Screenshot_20230903-182848
Hell yes, I think as people continue to discover how capable these cars are on track there will be that many more of us out there! One of these days I'd like to think I'll make it out to VIR, but that is a real hike for me; about 5.5 hours last I checked. My closest track is Summit Point, many great times to be had there as well and that'll probably be my first stop next season.
MrWeeks81
Arry
Vinton VA
I've changed the car a lil more now so downpipe, front pipe , intercooler. Surprisingly made 326 to the wheels , but to make up the gap on the rwd and awd cars I went to imw for tuning and had a custom session. So now at 383/394 I'll need to add a more aggressive pad hopefully something ceramic that won't damage my wheels or load them up with dust lol
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway PXL_20231003_153455035.MP~2
RamVA
McLean, VA
Nice work at VIR, Arry, you were moving. It was nice to meet you and to see your car.
I did see a ABP on my last trip to Summit, but I don't think it got on track. I won't get mine on track until next year, I think.
A3REDT
Thought it was quite interesting how similar your lap times with the Type S were to what I ran in my Camaro my first time out at VIR. Very impressive to be pulling those lap times with ~100 less HP than what my Camaro is running!
Acura Integra Track Impressions with Integra Type S at SCCA Track Night @  Dominion Raceway Screenshot_20231009_121229_TrackAddict
MrWeeks81
Arry
Vinton VA
Ram!! It was great meeting you as well man! Thank you I want to come back in November but I dunno yet
MrWeeks81
Arry
Vinton VA
Hey thank you I was nervous but I really tried to listen and figure out the track after the first day I got the hang of it. Alot of the time on track I was by myself alot
I'll be at VIR for the November Track Daze event! Hope to see some other ITS' out there.
