bandit81
- First Name
- Angelo
- Joined
- Jan 21, 2024
- Threads
- 6
- Messages
- 109
- Reaction score
- 42
- Location
- Columbus, Ohio
- Car(s)
- 2024 Type S, 1981 Trans Am (78 clone)
Could you take the wheel to a machine shop and have them first open the holes then re-machine a 60 degree shank for the factory lug nuts? This would obviously cost some $ but then you would not have to worry about using the flat flange nuts.
The use of the hub centric ring in this particular case is 100% required (someone else mentioned this but want to re-remind folks). Conical seat lug nuts center the wheel so the hub is technically extra insurance that everything is centered. In this case you are no longer centering the wheel via the lug nuts (when using a flat nut/washer). YOU MUST USE THE HUB CENTRIC RINGS OR ASSUME THIS WHEEL IS ONLY INTENDED HOLD THE CAR UP - NOT INTENDED FOR ROAD USE.
If you truly want to have a failsafe spare (idiot proof that any road side assistant will not screw it up), you should use a spare tire size that works on all 4 corners made of the same wheel material. This way the spare can be installed in the front or rear without question using an aluminum spare wheel for aluminum wheels or steel spare wheel for steel wheels so bolt torque is the same. In other words, get an 18" aluminum wheeled spare tire to be 100% confident nothing bad will happen. I think I am going to go this BMW wheel route myself, but I am going to put a big label taped to the wheel for anyone else who may come across it "NOT INTENDED FOR THIS VEHICLE UNLESS YOU FOLLOW SPECIFIC INSTRUCTIONS".
Last, in 2-5 years you may forget how to use this spare. Plan on writing down a procedure (move front wheel to back, use these nuts, use this hub centric ring, torque to X, etc..) and stash a copy with the tire as well as in the glove box.
Thanks for an awesome solution!
