Anyone having issues with carbon fiber exterior oem
Justpassedu
NY
S2000 , Pilot , 4Runner
I called my local Acura dealer in Valley stream NY regarding the issue , spoke to the manager directly who gave me a issue over the phone. Now I contacted Acura client relations and have them meeting me at that dealership to look at it next week. This should definitely be under warranty. Mine started having the issue at only 300 miles .
Coming back to this post I met a rep from Acura client relations at the dealer , he agreed to new parts , I told him it will most likely happen again as Acura does not use a clear coat . He let me take my car to there body shop where they sanded them down and added two coats of clear coat to the damaged parts . It looks much better , not perfect but way better . On a side note though this process left me with a my small scratch on my shift knob and steering wheel protector I had on from someone’s ring possibly , some white over spray on the rear bumper and black aero parts that I got off with alcohol myself and a small chunk out of one my tires . Nothing major but just proves my point of not liking to have my car at the dealer or body shop . I’m not even going to complain as I don’t want it in there hands again .
bdisco
Flashing my lights behind you
‘24 ITS, ‘21 Bronco, ‘15 Chevy 2500, ‘88 911
Update: Friday September 6th. Having not heard back from the dealer I stopped in unannounced when I was at the UPS store next door. The service representative said to bring the car around and take a seat in the lounge. The rep came out and asked me if I used an automated car wash. I said occasionally I will use a touchless car wash. He said they will perform a “one time only good will replacement “ of the defective trim parts, but from now on ”hand wash only”. I asked where it states hand wash only in the owners’ manual?
https://www.integraforums.com/forum/downloads/2023-integra-owners-manual.pdf#page659
So Acura sells expensive carbon fiber trim pieces with inadequate coating that can’t stand up to auto car washes?
Afgintegra23
Afgintegra23
Abel
Miami, FL, USA
That's crazy. Glad you got them to fix it. Mine is getting worst. I'm planning on getting a quote from a body shop to clear coat the spoiler and the mirror caps and see if it's worth it.
edido
ITS (TEP)
It might be better to PPF? It’s a small area and should not be very expensive.
Afgintegra23
Afgintegra23
Abel
Miami, FL, USA
But do you think the ppf would make the spot that lost the clear coat look like the rest?
bdisco
My email to Acura Client Relations:
I have an issue with the Acura Carbon fiber trim pieces. The clear coat is pealing. My dealer offered to replace the defective parts as a “one time only goodwill gesture”. The service representative asked if a used a car wash. Occasionally I will use a touchless (no brushes) auto car wash. The rep said from now on hand wash only. The carbon fiber trim pieces are not inexpensive and should be able to stand up to the occasional automatic car wash. It does not state “hand wash only” on Acura’s dreamshop in the description of the carbon fiber accessories. I believe Acura should stand by their accessories and fix these defective parts. I look forward to your response.
I wish you the best, but it honestly seems like acura doesn't care about these issues.
Having done some carbon work previously.... These are supposed to be prepreg parts, but they should still get a coating of urethane or poly after cure. The bigger issue is the carbon parts are coming with defects from the factory in the resin which indicates poor dry carbon quality. Dry carbon is essentially a sticky sheet because it has partially cured epoxy infused into the carbon fabric. The epoxy cure I'm seeing on my parts indicates it bubbled during cure, which means it either got too hot, not hot enough, or the resin didn't have a properly distributed catalyst. Sucks, but that's carbon for you. It's a very sensitive material, but thankfully it's really cheap to produce overall. Clear coat should help, and you can even do that yourself. Just wet sand with 600grit and spray with a can of water based poly.
bdisco
I implore my other forum members to contact Acura and file a complaint about the carbon fiber trim pieces. We should not be required to clear coat prior to installation unless stated so on the sales page description. Nor should we have to hand wash only. I live in New England it gets cold here in the winter. If enough people complain Acura will make the manufacturer make necessary improvements to prevent this from reoccurring in the future. “The squeaky wheels get the grease.”
https://crmshonda.my.salesforce-sites.com/service/acuraw2c
1-800-382-2238
Ayzoterik
Montreal
Acura Integra Type-S 2024
Not good at all. And me that convinced myself that paying for REAL carbon will be better against UV or either cold winter. 😣 I took delivery of the car in may 2024, I'll keep an eye on the spoiler too...
Afgintegra23
Afgintegra23
Abel
Miami, FL, USA
1-800-382-2238
Hi there. Any uodate on this? Did you get a response?
GotSeoul?
T
Mirror caps are fine for me, but the spoiler has almost the exact same spot forming now as OP.
Have had the car for nearly 3 months now. Never taken through a carwash hand washed only. I'm having a rim touched up by a local dealer in network (it's a Chevy dealer owned by West Herr, Acura dealer is 2.5 hours away) so I'll contact them and see what can be done. If not I can try the only Acura dealer actually close to me to see.
bdisco
Yes, dealership replaced rear wing and driver side mirror cap with the stipulation it was a one time only goodwill replacement. I was not happy with that response and also opened a case with Acura for fear the new pieces will delaminate as well.
The new mirror cap fits different compared to passenger side with no white trim showing underneath. The service manager said they owe me another cap when I come in for my next service.
