Baozzer 2024 A-Spec Tech 6MT
Baozzer
Baozzer
Bao
FL
New exhaust tips on stock exhaust ✅
I went with 4” slanted double walled tips. Asked for the tips to be extended out to the edge of the diffuser. Came out great didn’t want a droney and loud car.
Acura Integra Baozzer 2024 A-Spec Tech 6MT 9D390B10-D003-4333-9679-F53BD772D56F
Acura Integra Baozzer 2024 A-Spec Tech 6MT EBD98590-4B6C-4EB7-94E4-CA09BE27A81B
Acura Integra Baozzer 2024 A-Spec Tech 6MT 0B351C67-EC32-4430-A9B9-35B5DF1DA931
NecroFIesh
Greg
NoVa
'24 Integra & '07 S2000
Looking good Bao ?
-G
Baozzer
Baozzer
Bao
FL
Which mount do you the link? Thanks how was the install?
Blend mount from Amazon. Have to really push it into the fitcam to adjust mirror correctly. But it’s just perfect.
Baozzer
Baozzer
Bao
FL
Aluminum Radar Detector Mount for Valentine One - Compatible with Most American and Asian Vehicles - Made in USA - Looks Factory Installed,BlendMount BV1-2001R https://a.co/d/aKbdlxd it’s very expensive but worth it
@Baozzer
when youordered the fitcamx, did you opt to get the rear camera as well? If so, how did you go about routing it to the rear? Online it shows the rear is powered but the front cam which is awesome but if I pull the trigger on this purchase, I may want to get the rear as well
Baozzer
Baozzer
Bao
FL
I choose not to get the rear camera since this car is a hatch and you need to leave slack to open the trunk. I saw on Facebook someone did a really clean instal not showing wires but drilling a bit into the trim and following the stock wiring tube. Seemed worth it but at the time I didn’t want to deal with it.
Emunoz
Emmanuel
cocoloco92!!
LCM ITS
I see you picked your DE4 up from Pembrooke Pines Acura. Very nice. That's where AHC Garage operates out of. Car is looking great!
-G
They operate out of the dealer? I was looking to go see them and check it out
That’s correct. I bought my car from them last year. Briefly met Jonathan. Learned a lot from their videos.
Baozzer
Baozzer
Bao
FL
They make videos after closing for the day yeah
Baozzer
Baozzer
Bao
FL
25mm spacers ✅
Great fitment but personally would love 20mm more if it didn’t require modifications to stock lugs/rims.
Acura Integra Baozzer 2024 A-Spec Tech 6MT 1957F32F-BF30-4EA5-B946-8FE96508D87B
25mm spacers ✅
Eibach pro line lowering springs with spc rear camber arm (pre alignment) ✅
Are these sport line or pro line springs? Seems like a further drop than pro line
Baozzer
Baozzer
Bao
FL
Pro line. I thought the same thing. Looked lower than others. But it was right part number and everything and were the black springs not red ones
