clutch durability
wavyroll
Cross James
texas
2021 Honda Civic , 2020 Integra
Some folks had experienced slippage in the 10th generation at stock power levels.
Chances increase once you start tuning and the need for a new clutch should be a priority.
Does Acura use the same clutch unit as the Civic SI?
Same clutch. I didn't notice any slippage with normal power but if you get a tune you will see it in the upper psi ranges
RP2000R
WA
20 Lexus RCF TE, 20 Civic Si, 16 Tundra Pro CM, 15 Lexus IS350 RWD
I had 3 Si stock motor clutch fine if tuned goodbye OEM clutch!
RP2000R
WA
Dang phone messed up my sentences hahaha. I have owned 3 10th gen Si’s. The clutches are very weak any abuse or a tune and you will be replacing your clutch sooner then later.
Ha, ok. I thought I read somewhere that the CTR/ITS have a different, more beefy clutch. Is that my imagination? Aren't we good until about 400 Lb/ft?
Yeah the FL5/DE5 clutch is good for over 500hp from what I have read.
Question was the SI/Aspec clutch which is very weak.
Baozzer
Bao
FL
2024 A-Spec Tech 6MT
yeah im slipping a bit on map 2 with phearable tune in higher gears. don't notice anything on the 1-4.
