Bill
I agree with you, it's not very hot and would be nice if it could be a bit hotter. And I think the thickness also plays a bit of a factor. My wife's RAV4, on the other hand, does get noticeably warmer. That said, I think the heated seats are also subpar in comparison to other cars and get "just warm" instead of hot. Over time though, I've gotten used to it and appreciate having it over not having any heating.
When you say it "turns off" after a minute, do you mean it completely stops and you have to repeatedly hit the button again? I haven't had any issues with that - I wonder if somehow yours is drawing too much current or something, or you have a loose ground or loose wire somewhere?
Oddly, my seat gets so hot. Like in 15 seconds my ass is on fire. I can hardly ever leave the seat on 3. When it’s really cold, I leave it on 2 and it’s nice. When it’s 30-40 out, 1 is about all I can do.
for the wheel, maybe I had a bad ground or loose test wire that was switching off the heated function after button. Seems better now. And actually the polarity seems to make a difference for me.
car purple to black TTD
car black to red TTD
the blues don’t seem to matter, but if I switch the black and red wires, I get almost no heat.
I am fairly disappointed in the heat. The wheel is nice, but the heated feature is what I really wanted and it’s definitely sub par
Interesting - I just took some time to look through my videos and found that I have the opposite setup as you (red to purple, and black to black). Not sure whether this is worth mentioning, but the heat is only in 4 spots (10 and 2, and 7 and 5), and not the whole wheel like I would have liked. Although in comparison, the RAV4 has it in similar spots. I think the wheel thickness definitely has something to do with it.
Now I'm wondering if either there are variances in the heat with the seats depending on when the car was made, or our expectations/tolerances for heat are just different. I have noticed you can feel the heat from the seats rather quickly, but I've never thought they get unbearably hot.
Acura Integra DIY Heated Steering Wheel Install 1735837453084-9c
Bill
interesting. Maybe that’s why I’m feeling such varried temps. If 10/2 are hot, but 12 is just getting the left over, it might make sense. I did use it this morning on my 30° drive and it was better than none, so I’ll still call it a win. The shape of the wheel is really nice.
Yeah, hopefully with more seat time, you'll be able to do a more thorough test and see more consistent results. Definitely better than having nothing, although I still feel the heat even if I'm wearing a thin pair of gloves (I usually wear UnderArmour glove liners in winter).
I agree the shape and thickness is nice. After you get used to the thickness, it'll feel strange getting back into the average car with a "thin" OEM wheel.
Bill
So I have been back and forth TTD about the heated wheel. They are telling me (and their engineers confirmed) that the heat should be all the way around and not just 10/2 and 8/4. I was concerned mostly because I drive a ton with my hand at 12 and there is little heat there. I mentioned to them you had the same wheel with the same problem and they wanted to get us on a chain together to figure it out. You game?
Interesting. Sure, thread me in. I wonder if anything has changed in the last year since I had mine made. But I'd be curious to see if mine is supposed to be all around and what can be done differently if possible. I'll PM you my email address so you can add me to the emails.
Irishmykl
Mykl
Bedford, Texas
2022 MINI Cooper S
I feel like the heat button at the bottom is the most obnoxious location for a single function button.
Yeah it is very weird to have it there in the middle of the spokes, my MINI Cooper S (which is really a BMW) has it on the left side of the steering column below the tilt lever. It fine there cause it is out of the way. But if you didnt know it had the option you would probably not notice it was there.
eneka
Clarity EV
anyone else get a very faint "tick" when turning the wheel? Only started happening after putting the heated wheel in. It'll go away for a bit if I remove the airbag and check everything, but comes back after a while. Trying to narrow it down if it's wires within the wheel moving, a noisy clock spring, or that black plastic pin in the clock spring.
I haven't noticed anything on mine in 2 years. Is it a single tick each time you turn the wheel, or a series of ticks kind of like the sound a ratchet makes?
eneka
Clarity EV
very faint singular tick. Usually at the start of my drive when I'm doing lock to lock on the steering backing out of a space or in a tight garage. Very inconsistent too
