Homelink?
stanleywinthrop
23 A spec tech package 6 MT
Note, since the ITS already has an auto dimming mirror, you shouldn't need to run the harness like the FL5 needs to. You can tap into the power run for the dimming and save a lot of hassle. There is a walk-through on FB if you search this forum.
This depends on the part number of the homelink mirror you want to use. There are 2 options. If you go the route of colleghillshonda, you will need the additional harness as that mirror is not compatible with the harness in the integra. The FB route is a different mirror part # and it comes from the Civic and it is is compatible with the integra harness, but needs to be modified to jump power into homelink slot.
MaelstroM
Pradeep
2023 Integra MT
I think the mirrors do turn down, I don't know what the hell engages it though. My A-spec tech did it a few times, but once I moved my mirrors it stopped.
Confused me at first too! Leave the mirror selector switch in the R position, any other position disables mirror movement.
KevCarver
Kevin
Knoxville, TN
'24 Aspec 6MT Platinum White Pearl/Orchid
Can only speak for A-spec, but it will only turn down the mirror that is selected with the adjustment switch, so leaving it in the middle will have no mirrors turn down and there is no way stock to have both mirrors turn down.
Wow! Just seeing this 10 months in on my '24 A Spec Tech! Thanks, but I only have the right side move when the switch is on right. Left doesn't move with switch on left.
Was only checking in to see if there was any Homelink news. (No spoilers, I haven't read thru to the end yet LOL)
