need help with lowering springs
NEWTEGGY
Jerry
Gardena, Ca
good morning
i recently got the opportunity to own a 23 integra base model for cheap and need some guidance i have purchased a spec oem wheels as well as hub centric spacers i also got a rear camber kit question with the springs is which brand and what spring gives you the best ride and look with out losing comfort? any input is appreciated also anything else i should buy that im missing or should upgrade? i havent owned a honda since 98 lol thanks again
bisquick
Brandon
I believe H&R is generally considered to be closest to stock (at least for ITS). I would assume the same for non Type-S models.
99si
US
2024 ASpec
I went with pro kit and 20mm spacers. I wouldn’t want it lower for DD. Ride is similar to stock.
Roadtripper
Jerome
Lynnwood
2003 Honda S2000
good morning
I went with the Eibach Pros. It is a modest drop, but combined with a front splitter it requires much more caution. The ride is like 90% stock comfort, but the lower center of gravity makes it shine in the corners
Acura Integra need help with lowering springs IMG_5849
