Possible Engine Leaking
gemini19
2023 Integra A-Spec CVT
I was checking my oil today and noticed some oil residue in the area under the valve cover. I'll attach a pic but it might be hard to see what I'm talking about. Has anyone else notice some oil residue in that area? Is it normal for these engines? I don't drive the car hard and it only has about 5300 miles. I never noticed anything like this on my previous Acura.
Acura Integra Possible Engine Leaking 20231022_171206
I see what you are talking about. It could be residue from filling initially. I'm not seeing fresh oil. I'm seeing old dirty has been there a while oil. Wipe it off and check back later. If it shows back up you've got a slow valve cover gasket leak. Wouldn't be unheard of and is a very common area for all engines to leak.
gemini19
Thanks for your response. There was a lot more before. At first I thought it was just dirt. When I wiped it, i smelled the rag and it smelled like oil and gas. I'll continue to check on it and see more builds up again.
It smelling of oil and gas sounds more like an active leak. If it was just a spill you wouldn't smell gas. It sounds to me like you have a warranty trip in your future, unfortunately. Keep an eye on it and update anyway to be sure!
SharpAndy
Andrew
Liberty, MO
2023 Acura Integra A-spec 6spd
Oh heck, I have the same thing going on right now. thought I was crazy that a new car would already have a valve cover gasket leak. I checked all the bolts and none were loose. Guess I have another phone call to make...ugh, this is getting old.
gemini19
I took it to the dealer and they replaced the gasket under warranty. So far it seems the issue was fixed and is no longer leaking.
SharpAndy
Andrew
Liberty, MO
Glad to hear they took care of it. My car has been in for so many things already, they're probably sick of seeing me. So I'll just add it to the list...
