Noice! You get the rear belts figured out or is that a no-go?Added OEM Type R shift knob and nut to match the seat belts!
I think so, found a company that could swap the straps, just havenβt found the time to get the stock ones out.Noice! You get the rear belts figured out or is that a no-go?
I tried the universal cap from Motive... if "tried" meant took one look in the bag, laugh/cried then yelled for my kid to come downstairs to pump the brakes manually.That's pretty tight clearance. Just curious, how much room between the bar and cap? Enough to get a pressure bleeder lid on?
One of these, https://a.co/d/0bjw1D7TI tried the universal cap from Motive... if "tried" meant took one look in the bag, laugh/cried then yelled for my kid to come downstairs to pump the brakes manually.
What are you using?
this is the exact same set up I use and it works great! Itβs definitely a tight fit, especially removing itβ¦but it doesnβt lose pressure, and thatβs what matters.One of these, https://a.co/d/0bjw1D7T
I used my own fittings to make it fit the motive, and it's a snuuuug fit. That's what you want though, but just make sure to rub a little brake fluid on the gaskets first to make it easier.
wow, this looks great. How much did powdercoating run you?Had the factory graphite wheels powder coated bengal silver and put on conti dws06+ for winter. Bronze set for summer.
With the contiβs I seem to be rubbing a smidge with 20mm spacers so will put the 15mm on the rears.
Was about $800 all set and done including Mount/balance. I provided the TPMs. Didnβt change anything one bit. No disadvantages They sand blasted the previous color off first.wow, this looks great. How much did powdercoating run you?
Any disadvantages at all to powdercoating wheels? i figure the weight would be nominal.
