vicembn
brandon
Tennessee
2023 acura integra
Eibach Sportline springs
(part # E20-40-036-02-22)
(From 10th gen civic si)
also installed rear camber kit to minimize natural camber from the drop.
(Skunk2 2023 Camber Kit)
(SKU: 516-05-1605)
Acura Integra 2023 Integra Eibach Lowering Springs + rear camber kit installed BD0C4B32-8030-49F3-B6E2-42955BCB6906
Acura Integra 2023 Integra Eibach Lowering Springs + rear camber kit installed 6F3AA346-1441-4A32-A7E7-810E401BE29A
Love the drop, but it needs spacers desperately.
vicembn
vicembn
brandon
Tennessee
2023 acura integra
Also, we’re your springs noise free as soon as they were installed or did they take a little “setting In” before they got noise free ? I’d appreciate the help
Noise-free from the start. If you’re having noise, make sure everything is lined up correctly and all bolts are torqued. The install is 80% of it.
vicembn
vicembn
brandon
Tennessee
2023 acura integra
I’m having a good bit of noise when turning so I’m gonna check everything.
I've had the same issue with lowering springs in the past. I know coilovers are harder with this platform because of the adaptive dampers....but a good set of coilovers would ride better than stock anyway with the nice lowered ride height. The aftermarket will still take some time to make the good set but it will end up being a product.
Did you finally get the noise sorted out?
vicembn
vicembn
brandon
Tennessee
2023 acura integra
Yes I fixed the noise, I just checked the torque on everything, And added a little bit of grease to the top hat that connects to the strut, as during Install most of it rubbed off. Noise is now totally gone 👍
vicembn
vicembn
brandon
Tennessee
2023 acura integra
I like the stance on this! Debating getting these or tiens…
These give a great ride quality for lowering springs, as for tein I didn’t see anyone give a good review, so I went with eibach
Tegra808!
2023 Acura Integra Aspec
whats the wheels gap with the sportlines and is the tires tuck slightly?Any side shots?
Also, when installing the front springs, any problems with the axles popping out?
Tegra808!
(SKU: 516-05-1605)
Are those the stock springs (blk)? I thought Eibach Sportlines where red springs?
Nycvic
Vic
NYC
2023 Acura Integra A-Spec 6MT
Love the look. Going to order my Eibach lowering springs soon!
I saw comments about spacers, what size spacers you going for? And would there be a possibility of needing longer studs to ensure proper tightening of the lug nuts?
