Adding memory drivers seat
jayy_swish
I don't see a driver's power seat control module in the wiring diagram you posted, or did you mean unit vs. module? Wouldn't that be the unit/module on the seat bottom w/ the switches? Just grasping at strings here since I haven't seen the ITS wiring diagram for comparison.
The diagram I posted is the ITS’s so there would not be a power seat control module, the aspec w/ tech will have one. I didn’t post the B can network wiring diagram or the seat diagrams. I can post them up once I get to work.
edit: scratch that it was the spec’s diagram sorry getting confused going back and forth. Regardless I’ll post those diagrams of what I’m talking about
jayy_swish
Here is the aspec w/ tech 6mt diagrams for the B-can communication (the communication between the BCM to the body modules) and the power seat diagrams as well as the ITS’s. I named the files to distinguish them but the top header on the diagram will tell the vehicle as well
View attachment Aspec w-Tech Power Seats (KA USA DE4) (Seats).pdf
View attachment ITS Power Seats (KA USA DE5) (Seats).pdf
View attachment ITS B-CAN Communication Line (KA USA DE5).pdf
View attachment Aspec w-Tech B-CAN Communication Line (KA USA DE4).pdf
jayy_swish
What this diagrams tell you is the ITS and aspec have different seat switches. The ITs are normal old school power and ground switches and the aspec switches run to the seat control module before directing power and grounds to the motors. For anyone too lazy to read the diagrams ?
Edit:
Aspec w/ tech seat control part #: 816543S5A21 , cost is showing me $188.23
ITS part number # I’m not seeing yet on my side at least
acurax
2024 Acura Integra Type-S
Edit:
Something interesting I noted regarding the description for that part is that it states "(8WAY MEMORY)". Also, the diagrams in Dreamshop only show two switches, the other being the 8WAY for the non-Tech trim levels. Maybe they haven't updated the diagrams for the 2024 model year?
jayy_swish
Let me take a glance at the non-aspec seat controls diagram to see if it’s the same set up as the ITS. They might just share parts
Update: took a glance at the non-aspec integra which does not have the memory seats and it does in fact share the same set up as the ITS. Which in this case the ITS would share the same part as a non-Aspec. So yes the 8way only switch is what the ITS would have. Again don’t have the ITS part numbers on my side but a non-Aspec switch part number is: 81653SDBA71
jayy_swish
Took a glance at a 2023 Civic Type R to compare as well since that is more closer to an ITS than a ASpec. Diagram also matches the ITS and non-ASpec in regards to the seat controls. Part number is also the same as a non-ASpec P#: 81653SDBA71 $77.83
wontondon
Ontario, Canada
DE5, MK7 GTI
Are you a detective?
acurax
Interesting, I can't seem to find that part in Dreamshop. I did notice that the CTR driver's seat has manual height so they may be able to add power height control w/ some ITS part(s). Googled that part # and it looks to be one they've used across the Honda/Acura lineup.
GotSeoul?
T
Any luck on this project?
I need to know. My girlfriend drives sometimes and she's really short so the seat is basically all the way forward after.
On the flip side too the few times I've had it at a dealership whoever moves it must be 7' tall because the seat is as low and far back as possible.
Like that I can't even reach the clutch at 5'9 ?
bandit81
bandit81
Angelo
Columbus, Ohio
Giving this thread a bump. I wonder if the aftermarket can make something that interfaces with our drivers seat to allow us to push a button and restore the seat to a specific position (memory seat feature). I got back from the dealer scheduled oil change and I am finding myself making lots of little adjustments to get my seat back where I had it.
APBonABP
US
2025 ABP//Black Type S
Yeah I'd be interested in this, too; the lack of seat memory is by far my biggest issue with this car. Especially since some of the other trims (and my other car that's nearly old enough to drink) have them.
4Dparadox
NY
Integra Aspec/Tech Manual
2025 Aspec tech 6MT here I installed the Mikstore F auto folding with reverse tilt Honda oem mirrors. I can confirm while the auto folding mirrors work… however I lost usage of the memory seat switches on my door. The switched light up still but are non responsive to the press. If I put my old window switches back in they work but then the auto fold mirrors do not work.
Also my reverse tilt that I’m pre wired for lowers the passenger side mirror however when leaving reverse to neutral or gear instead of the mirror going up it goes all the way to the right. Not sure what’s wrong with that. Since I’m pre wired I didn’t think I needed to do anything extra.
Also my memory seats still remember the positions based on the key I’m using. I just can’t edit those positions with the new switches in for the auto folding mirrors.
Any help on getting it all to work would be appreciated.
acurax
Have you reached out to Mikstore via Facebook to see if they may have run across you issue before?
