Battery Tender Hook Up
Nicky Pass
Chicago
2024 MBP Integra Type S
Hi everyone...its coming to the end of "car season" in the Chicagoland area. I have had many cars that I put away for the winter and I always use a battery tender.
Does anyone have pics/instructions/suggestions on where/how you actually made the connection to the battery?
Thanks for any help.
crepr12
North East
24 ITS Black on Black
"I have had many cars that I put away for the winter and I always use a battery tender".
ITS is just a car same process should work...
South West
Integra
This is the second thread about storage already. It's just like storing away a Camry TRD.
Nicky Pass
Chicago
When I had my GT350, there was like 3 ways to hook up the tender. Sometimes....there are tricks/tips from people that have done it already....
When I buy the charger, it comes with a small wires with a plug on one end and terminals on the other. Connect the terminals to the battery post, and leave the wire there all the time. Then, when I need to connect the charger, I connect it to the connector, and after in an outlet. Simple as that.
I'll grab some pics this weekend. Basically I attached the ground clamp to the other side of the wire, and both on the side so that I could lower the hood easily.
I also plug it in for 12 hours about once every two weeks. Yes I know the battery tender is safe for 24/7/365 use, however I'm a belt and suspenders type of guy.
Also ordered a Car bag since my wife parks her winter driven car 2 feet from it.
I did 6000 spirited miles this season and I intend to keep this car (if possible) until the second half of this century. Living in the rust belt and driving in the winter simply would not allow that to happen no matter how well you try and maintain it.
Clamp it to the battery terminals?
No kidding. It's a Civic.
Mr. LargeCoffee
Liverpool NY
For my Miata I just yank the battery, put it on my work bench, connect the battery tender and come back in the spring to get it. Doesn’t make a difference, I just prefer having the electronics depowered for the winter.
bdisco
Flashing my lights behind you
‘24 ITS, ‘21 Bronco, ‘15 Chevy 2500, ‘88 911
Ford does have a Battery Monitor System module on the negative side that is supposed to help prevent you from draining your battery all the way down.
South West
Integra
Why does everyone talk about their other vehicles? I have a battery tender on my Triumph motorcycle.
My bad for the delay. This is how I connect the alligator clips for the winter. Note the negative terminal is jumped so I use the other side of this jumper for even easier connection.
I then lower the hood slowly until it latches but not enough that it locks. It should be the same height as when you first pop the hood, enough to get your fingers under there.
Mine is entering it's winter sleep this Friday and won't be back on the road until at least April 1st 😩. While it's tough, it's worth it to me.
Acura Integra Battery Tender Hook Up 1000002992
