Best spacers
AdreeN
Andrew
Toronto
2025 ITS
Any strong recomendations for 15mm spacers for stock wheels purchasing in Canada? Do not want to get hit by tariffs/customs.
Looking for cost effective, but proven reliability/durability.
Thanks!
Two Step Performance
Elite Sponsor
twostepperformance.com
23 FL5 Civic Type R
Be aware that in some cases using 15mm spacers require cutting the factory studs because they otherwise interfere with the back of the wheel. A 20mm spacer is a safer fitment option. 20mm in the front and 25mm in the rear is flush.
AdreeN
Andrew
Toronto
2025 ITS
Can anyone with 15mm spacers confirm I'll need to trim the OEM studs prior to installing?
If you have a type s, then there's no problem with stock wheels, they are drilled out on the back.
lumper
2007 Nissan 350z
Thanks!
I went with Bonoss 6061 al 25mm spacers.
They make 7075 al too, but I went with the 6061.
I love them, well made, look great, easy install.
I also went with 275/35/19 tires for my all seasons so the fitment in the pics is the combo of spacers and larger tires.
Acura Integra Best spacers cde1b07e-ab10-4664-812c-acbee8e366e2
Acura Integra Best spacers 54efcc60-2e94-4ebf-855a-921aa3a5fd0a
Acura Integra Best spacers 164ea627-469a-4bb6-b776-6c4994fe873b
Acura Integra Best spacers 92f65bf6-5dee-4c03-b63e-4b7a3ab6a1d3
Acura Integra Best spacers 99ce2985-563b-4cf7-8207-be5663946ad2
AdreeN
Andrew
Toronto
2025 ITS
Sheeesh, nice. U on lowering springs?
AdreeN
Andrew
Toronto
2025 ITS
Not a bad combo at all...
Ended up with 15mm bonoss as i like the flush look. The tires def make a huge diff in wheel gap, def an interesting idea instead of lowering.
Hows the ride quality? Must be extra comfy now
lumper
2007 Nissan 350z
I love it, softer on the potholes and overall performance has been great.
When I replace my Michelins I am, going to go 275/30/19 I think, not sure yet, debating, I do like the added sidewall both for cushion and looks.
I didn't want to mess with lowering the car, I like being able to get my jack under there easily for oil changes and I really like the stock wheels.
TXWayne
Wayne
DFW
wheresjc
Jose
S2000, GR Corolla
15 mm and 20mm Bonoss on mine with H&R lowering springs, no need to trim any studs with factory wheels. Zero rubbing as well.
