Help! No one can figure out this issue
integra__gang
integra__gang
Eddie
Las Vegas
ā€˜24 integra Type S, ā€˜97 Integra LS, ā€˜95 integra SE
I don't know much but it sounds like a fuel/air issue from your start up video.
Fuel pump... prob not
Maybe your flex fuel system... reflash the hondata map back onto your ecu.
Also.... everytime i mess with intake near the throttle body, i do a throttle body idle relearn.
That secret handshake with pedals and on off button sequence.
Sorry if i wasted your 27 seconds reading this.
How do i perform the idle re-learn? I reallyy hope itā€™s as simple as that!
and I did use a smoke machine to check for vacuum leaks and I didnā€™t see any smoke anywhere except for the catch can hoses that got brittle, which I replaced but now Iā€™m going to remove the catch can entirely, everyone seems to say thereā€™s more cons than pros.
Iā€™ll do idle relearn and catch can delete before having to remove the bumper, Iā€™m not looking forward to removing a million plastic clips for the bumper lol
SocalDE5
LA County
2024 its
It is a sequence, I do not know what it is. Youtoob or google could be a start.
I saw the idea of cleaning the MAF. This is simple and a good idea.
I have read some airl filter charge fluid can gunk the MAF
MacKharoni
Minneapolis
Civic 06 si, Infiniti G37, Acura Integra Type S 24
I had Oil PRL cobra air filter before on my FK7. Car was shaking and idle funky. The K count on my ktuner went from .49 to 1.60. I replaced air filter and it didnā€™t change anything. I cleaned the MaF sensor even though it I didnā€™t see any gunk on it and the problem disappeared immediately.
integra__gang
integra__gang
Eddie
Las Vegas
Today I did the idle relearn, removed the catch can, cleaned the maf sensor I even reflashed it back to stock for a bit and nothing changed whatsoever..
Iā€™m at the point where I want to remove my injectors to go get them cleaned but I donā€™t want to spend any more money on this ā€œguessingā€ game Iā€™ve been doing all along
SKINNIE
DFW TX
ISF, 23' BB FL5
The Hondata base wasn't really all that great to begin with. Now you're running the E85 base map and threw more mods at it.
You need to smoke test from MAF sensor back, the whole intake system. Also I have heard mix opinions about the idle relearn dance working. Unless you have a scan tool to verify, your erasing throttle learn values and doing the idle relearn with an ā€œidle relearn completeā€ PID you donā€™t know if it actually did it. The steps are the exact same but the scanner actually erases the learned values and tells it to begin the relearn process.
Without a good scan tool youā€™re just going to be wasting money and guessing. Have to bite the bullet and get one. Donā€™t personally have this but others swear by it. I have a Autel, but should do the same thing.
https://a.co/d/9EbVqU6
Check fuel trims. Short fuel trims and long fuel trims. If you are running lean because of a vacuum leak youā€™ll see the fuel trims favor towards the positive trims. The vehicle is dumping extra fuel to compensate for the leak.
integra__gang
integra__gang
Eddie
Las Vegas
Thank you bro, I have a friend that has an experience snap on scanner Iā€™ll see when heā€™ll be available to connect it and check it out, Iā€™ll get back with you on the results
I did put a smoke machine from the maf housing and left it on for a while I didn't see any leaks except for the tinyyy tiny leak from the catch can but even when I removed the catch can it kept making that same thing.
Also double check your ethanol %. On my 10th gen civic when I had my flex fuel kit I started running into a p0300 (random misfire) and when I was looking at the live data I would see my ethanol % jump around drastically. All because I had a lose ground connection. So I would also check that.
Seeing how the issue happened when you installed the intake, charge pipes+intercooler. I would also definitely start there. If you donā€™t see any leaks with smoke and have a good smoke tester that pushes air I would add some soapy water to all the joints/connections and see if it bubbles
