Yep. Every flash they need to be re-enabled.
Maybe it's a Hondata thing 🤷
ZeroGSR
2024 Integra Type S (LCM)
Is that why I haven't been getting any beeping??? Ha, will re-enable. Also being on PST, resetting the clock sucks.
TypeSJ
Jamie
1993 Mazda RX7,2004 Subaru Wrx Wagon, 2017, Subaru
Your parking sensors will work with any calibration. After flashing, re-enable them and they'll be on.
Just flashed the TSP. How do I re-enable the parking sensor?
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
A bunch of Honda/Acura stuff
Via your steering wheel controls, the same way you do in factory form. :)
You good sir, have sold me. Just placed an order! DP is next
Get a TSP dp since it has the stock number of cells it won't throw a code. RV6 has fewer cells and throws a code.
Right screen on gauge cluster under safety.
TypeSJ
Jamie
Ahhhhhhh got it. And yeah I’m going for the TSP DP
ckone2030
Christian
Atlanta, GA
Flashed my ITS with Hondata today and was surprised how much more fun the car is. One question to the experts here. When I take the car for scheduled maintenance, should I flash it back to factory? I don’t want them to void my warranty or is that a mute point once the ECU is jailbroken?
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
Honda's i-HDS isn't sophisticated enough to discern the "jailbreak" status of the ECU. It can see the software ID (which if the factory calibration is flashed to the ECU, will be correct), and the number of key cycles since the last DTC-clearing event.
To put things simply, flash to start and drive the car a handful of times.
ZeroGSR
Anyone know how the pedal dance affects the Hondata traction control? Will it be disabled in diagnostic mode like the stock TC, or will it still function? Also, does Hondata have actual Launch Control? I haven't tried dumping it yet to see, but will be on track next week.
Good question.
I'm running Pherable Tune and I think MAP4 disables all Traction Control. I haven't tested but it saying this makes it seem that pedal dance is no longer needed.
It also comes with a 4k Launch Control. I have not yet dumped the clutch or sat idle and stomping on the pedal but it's there.
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
Once you mod...its your dime or its that no longer the case...you play you pay....jmho...
The burden of proof that a modification is the cause of your warranty claim is solely on the accusing party.
crepr12
North East
24 ITS Black on Black
I'm not against mods...but people should know going in that there is a risk...
