Sticky/Jerky Steering issue
BarracksSi
DC
'17 Civic Sport Touring Hatch; '17 CR-V EX. Formerly '02 EP3.
Imperial
Slava
Update on the new steering rack...
It's beautiful! The sticky steering is gone, but overall the steering feel is much improved.
Do you use Android Auto/CarPlay and AcuraLink app?
evanescent03
'24 Z06; '24 PWP ITS
This should be a sticky. Pun intended. Glad you got your car sorted! I have a friend with an FL5 who is having the issue as well.
Zircular
TN
GONE: ‘23 Integra A-Spec 6MT
I think I've started experiencing this in my '23 ASpec that just crossed 12,000mi. What I'm feeling is as if the steering rack "goes to sleep" whenever I drive straight ahead, and it takes a few degrees of movement before it "wakes up" and gives me power assist again. It hasn't prevented me from maneuvering but it's an odd sensation. Not a fan.
TrackRider54
Chad
Kingston Springs
2024 A-Spec Tech
Yep. That’s it. Time to order the updated rack.
I took my car in yesterday to have it diagnosed and they ordered a new rack. They advised me that it would be some time before a part comes in and let me take my car back for the time being.
BarracksSi
DC
FWIW, this is one of those issues that'd make me very wary of driving the car. I could tolerate things like a bad window motor or even a hole in the tailpipe, but a problem with the steering can turn into what they'd call a "significant safety event" when it goes bad.
TrackRider54
Chad
Kingston Springs
2024 A-Spec Tech
Mine wasn’t a safety issue as it was just a “glitch” in the rack. Everything was still functional. But I get what you’re saying. The NHTSA has had a few crashes attributed to the issue.
Agreed! It has been as is for quite some time and I was advised it likely wouldn’t get worse than it already is. Hopefully they get the new rack sooner than later though for sure!
PJK3
Philip
Louisiana, USA
2023 Liquid Carbon Metallic / Red A-Spec Tech
The backordered steering rack finally came in, and I brought the car to the dealer on Friday.
They put me in an Integra CVT A-Spec (non-tech) again, and I had the fortune of getting to try the slow traffic auto drive mode, which was pretty cool. (Not cool enough for me to give up the 6MT tho. ;))
They returned the car on Monday (had another unrelated minor issue that delayed things), and I have to agree -- the steering feels much more tangible and less detached from the road. It's hard to explain. I can't rule out the placebo effect either.
Unlike TrackRider54, my listed part was 53620-355-A24, not the A34 part.
That said, they did show me the alignment, and it was virtually identical both before and after. It wasn't great especially around the camber -1.1 deg and -0.2 deg L&R respectively. Toe and Caster were fine all around. They told me the car has no camber adjustment at all. :dunno:
The sticky feel is gone and the car tracks and drives true, so I'm a happy customer.
To Imperial's point, the steering wheel now isn't true to center. Based on this random circle segment illustrator I found online, I'd estimate it's about 3-5 deg off center to right.
Coincidentally, my oil change alert popped up the next day on the way home from work, so I'll ask them to fix the steering wheel alignment when I bring it in for my 2nd complimentary change.
Imperial
Slava
Good that you got your issue sorted out. I wonder which Integra gets A24 or A34 racks. How are these different?
I know that some vehicles may not have caster adjustment, but not having camber... If the caster is some degrees off, the steering wheel may not return to center after a turn. I had that on my Acura RL, but later was corrected by another shop. Before disconnecting steering rack, tech usually ties steering wheel to something, so it wouldn't move freely.
TrackRider54
Chad
Kingston Springs
2024 A-Spec Tech
Best I can tell is the A24 is for 6M cars and the A34 is for CVT.
