Bolt pattern for A-spec is 120mm not 114mm?
Danman4246
Bridgewater, MA
'23 Integra, '04 Element
Purchased 114mm bolt pattern(didn't fit)wheels only to find out Integra has a 120mm bolt pattern since you measure from the center of one hole to the outside edge of the one directly across from it on a 5 bolt wheel.
Even number bolt patterns are measured CTC, odd number patterns are center to outside edge. Go figure.
Mr. LargeCoffee
Liverpool NY
It’s not really to the outside edge. If it were a 6 bolt pattern the measurement would be to the center of the stud directly across which would be on the line drawn from the 2 outside edges of the 5 bolt pattern. In other words the bolt pattern dimension is just the diameter of the circle that the bolt centers are on regardless of the bolt count.
Roadtripper
Jerome
Lynnwood
2003 Honda S2000
Aspec is definitely and without question 5x114.
Brooski1
Bruce
Pennsylvania, USA
2024 Acura Integra A-Spec Tech 6MT
Gernett
Sonny
Minnesota
2014 MDX SHAWD Tech,2024 Integra Type S PRP
There is no way 5x114.3 doesn’t fit, if it doesn’t fit your stock wheels won’t fit on them either. You must bought the wrong wheels.
What year Subaru? 2014 and older are 5X100. Looks like that's what you have.
OEMjoe
Joe
23 Integra, 99 Audi A4
Don't they have different center bores too? If I recall, Subaru has a smaller center bore for the hub than Honda.
Two Step Performance
Elite Sponsor
twostepperformance.com
23 FL5 Civic Type R
Yes, the new 5x114.3 wheels from Cobb don't fit Hondas because of this.
But the other obvious scenario that everyone is ignoring here is that maybe the car is actually a Type S and Dan just didn't realize it beforehand. :p
This. Non-Type-S has a bolt pattern of 114.3x5 with a center bore of 64.1mm. Not sure why this is even a debate. Integra Type-S has 5x120 bolt pattern.
WRX wheels posted for sale incorrectly or specs assumed incorrectly by buyer.
Someone close this thread. LoL
Actually, Acura measure their bolt pattern from center to center, Subaru measures theirs from center to outside edge of bolt hole directly across from it. Both cars claim to have a 114.3 pattern. But measure differently. Find a friend who has a wrx and see for yourself. It's odd.
I'm not saying that you're wrong. But, I can't find anything that supports what you are saying. Everything I can find verifies that bolt patterns are measured the same. 5x114.3 is 5x114.3 whether Acura or Subaru. The wheels might not interchange due to other dimensional differences, but the bolt spacing is the same.
I looked at your photo again, and the Subaru wheel is a 5X100 pattern. A 114.3 is 4.5", and 100 is a bit less than 4". Your measurement makes it pretty clear. Subaru uses both sizes on many different cars. A two year old WRX should have the 114.3 pattern, so it aopears that someone was mistaken about the year or model.
