Short answer, if you live somewhere with emissions and are keeping your stock cats do not put a BOV. Also if you plan on keeping the car long term do not put one on.Hey everyone, new to the modding scene but was interested in installing a PRL intake as well as the boomba bov adapter, however, I have not heard much about it. Is the adapter safe to install or will it cause issues in the long run?
I am not sure if this is the same thing, I put a link to what I am talking about, it's a BOV adapter, but please correct me if I am wrong: https://www.boombaracing.com/2022-civic-acura-bov-adapter/Short answer, if you live somewhere with emissions and are keeping your stock cats do not put a BOV. Also if you plan on keeping the car long term do not put one on.
This turbo system isnāt designed for a BOV, thatās why thereās not much talk about it
See my explanation here, post #15I am not sure if this is the same thing, I put a link to what I am talking about, it's a BOV adapter, but please correct me if I am wrong: https://www.boombaracing.com/2022-civic-acura-bov-adapter/
We have a bypass valve, and need the air to recirculate.. almost like a closed air system. What youāre looking at is a BOV which vents the air out. Although it retains the bypass valve it is still venting the air out which is bad in the long run
That is a Boomba BPV, different from the Boomba BOV. 2 different products, 2 different designsThe Boomba BOV/BPV has "recirculating" in its product description: https://www.boombaracing.com/honda-acura-1-5t-2-0t-3-0t-bypass-valve/.
Honestly not needed the stock one is fine and adequate, those $200 can be used else where and the Boomba BPV will not give any additional turbo noisesThanks for that! Any reason to not do the BPV?
Only bad thing with a SRIās is it will heavily retard (pull back) timing once it gets heat soaked. Not great for performance, but definitely great for soundI know it's an older thread, but do you want the BOV loud pshhh sounds and hear your turbo?
27won short ram intake. Made by a reputable company, doesn't mess with fuel trims and no issues. Had mine for 5k miles now.
Sounds good! Link to the recirculating version?I've been happy with my boomba bpv for the DE5. No CEL and is full recirculating.
