ITS Door Rattle - Maddening
wickedgoodheah
Bill
Integra Type S
I’ve searched around this forum and tried everything in those other posts, but man, I’ve still got a rattle in the passenger door. It comes and goes on long trips and it certainly happens on bumpy roads, but I can’t figure it out. I took the door card off. Taped and sealed everything I could think of and still have it. One thing I notice is if I put pressure on the door handle (pushing the door outward), the rattle goes away. If I pull the door towards me, same thing, the rattle goes away. It really sounds like it is coming from the seat belt area, but 100% goes away with small amount of pressure applied on that door either pressing out or pulling in.
Any thoughts?
ITS_320
James
KCMO
'22 Accord 2.0T/10AT, '24 ITS
I have the same rattle, I've been putting up with it for a year. Front passenger door, if I push or pull on the door card it stops. Sometimes cracking the window makes it stop too but then it comes back quickly after that.
Both the latch in the door and on the loop on the frame of the car are tight with zero play.
Ayzoterik
Montreal
Acura Integra Type-S 2024
I also have this noise coming from the passenger door. Can't find where, but I read somewhere it was caused by the seatbelt adjuster. Will definitely have to check it out soon.
wickedgoodheah
Bill
Integra Type S
Mine was the door latch. I cranked it down on the door and the frame and it did go away. But I do have another rattle near the center overhead light near the mirror. I give up with it. This thing rattles way too much.
Ayzoterik
Montreal
Man, I must admit, I love my car, but at that price, we expected them to be top notch out of the assembly line.
TEPTeggy
Las Vegas
For me, the rattles come from several different locations, never consistent and never at the same time. I don't get it lol.
Ktrw
Zach
My car has the passenger door and center dash rattles as well. Rough roads make it more apparent and to some extent so far they're temperature dependent.
My center dash rattle that would turn in an annoying buzz/whine under medium rpm and high throttle input was diagnosed by the dealer as the plastic back trim of the infotainment screen. Once it makes the noise, if you press back there and it stops, it's the same thing. The dealer pulled that piece and replaced it with a new one as well as added some additional felt tape. It seems to have solved it for now.
BCH
Northern Virginia
I have a new 2025 ITS, and it developed a buzzing sound from the passenger door area at 500miles on the odo. Sound occurs mostly during hard acceleration. Almost sounds like static or a blown speaker. Took it into the dealer, and they said they need to have an Acura specialist come take a look, and would have to be in the shop for 4-5 days. They said that this was a known reported issue. Annoying to say the least.
TampaDE5
Zach
Tampa
I have the exact same issue. Almost sounds like static. Good to know there is a fix.
If you get a constant "static" type noise, it could also be the bottom of the infotainment screen. There's a tsb from the civic from 2022 and the integras have the same issue because they didn't apply the tsb moving forward.
When the noise happens, if you press on the plastic dash bit under the screen and it goes away, that's the issue.
TampaDE5
Zach
Tampa
Yes !! Mine actually only happens at about 2k-2500 rpm and I have pressed on it and it goes away. Ugh.
It's an easy fix at least. You pull the dash trim, pull the screen, put some felt tape in a couple areas on the bottom and then reassemble.
You can make the dealer do it so if they brake clips along the way it's on them to replace. You could do it yourself as well and just make sure to replace all the clips that the dealer would just reuse, and that would prevent future noises from the tear down. 🤷‍♂️
BCH
Northern Virginia
Update. My 2025 ITS is still waiting at the dealer for an "Acura specialist" to take a look at it. I asked them to just take a few trim pieces off, and add felt tape. But they claim that because its under warranty, and its a known Acura issue, they have to wait for the specialist to diagnose, and they can't just do it by themselves. C'mon Acura - just send a service bulletin out on what to do.
