OEM Lug Nut/Rim Ball Seat Specs
Pow-Pow
George
Salt Lake City, UT
Acura Integra Type S
Does anyone know the specs of the OEM lug nut/rim ball seat. German cars use numbers like R12 R13 R14 to describe the seat. Was trying to find the specs on the OEM Type S ball seat for 14 x 1.5 lug nuts. Just haven't seen the 'R' number of the seat.
I think it is just ball seat. No other specs.
Conical seats may have different angles, but not the ball seat.
If I'm wrong, I'll learn something!
s219
Virginia, USA
Too many
According to this pretty thorough evaluation, they are R14 and same as Porsche:
https://www.civicx.com/forum/threads/lug-nut-solution-for-nsx-wheels-solved.42281/
Can't confirm as I've never looked into this myself though. Always just gotten them from Honda and the radius was never mentioned, just "ball seat".
If you have a drafting template for circles with mm sizing, a 28mm circle should let you confirm if it's 14mm radius.
Pow-Pow
Pow-Pow
George
Salt Lake City, UT
Think 14 or R14 is spot on to the correct seat. Was looking at some 14x1.5 R14 Porsche titanium lug nuts, just was double checking. They are 1/2 the weight of OEM lugs.
I just measured the oem lug nuts. They are 25.25mm at the seat, which makes them a 12.6mm radius. The better fitment would be an r13
Actually I take this back. The ball section is pretty shallow on the oem lug nuts. R14 is appropriate. You could fit an r13 without any concern as well, especially a deeper one.
