Parking w/ brake Control Module location?
c34webb
Clint
Nashville TN
2024 Acura Integra A spec
I purchased this module to repair my wrecked 24 integra. Can't seem to find out where in the world it goes. Any ideas? part number 39670-3S5-A05
Acura Integra Parking w/ brake Control Module location? tempImage4Uhv2Q
c34webb
Clint
Nashville TN
Interior Trim Area File it will be listed as "AC" in the diagram
EDIT: realize the file doesn't look as easy to read as the online format lol, but if you scroll down you'll see it under the AC sub procedure. Ill attach a picture for your convenience
View attachment Interior Trim Area (Interior Moulding _ Trim).pdf
View attachment Parking and Back-Up Sensor System Component Location Index (Except Type-S) (Collision Avoidanc...pdf
Thanks so much! Found it, replaced it and still an issue. Dang.
c34webb
Clint
Nashville TN
B2600-54 is parking sensor not initialized, try doing the rest on the parking module:
EDIT: just saw your other thread. Can you try erasing the code and seeing if it’s selectable? If not I would go into the data list in the module and see if all sensors are providing data
View attachment Resetting The Parking and Back-Up Sensor Control Unit (Collision Avoidance Module).pdf
Yeah I’m not able to reset the PSR system via the dash since the function is in red. The data shows every sensor at 0 yrds even on a moving graph while moving objects closer to the sensors.
If there's no data being transmitted when you move something closer or further away then I would verify power and grounds at the module and then at the individual sensors.
As an added check I would verify the connection from the sensors to the module by Ohms checking the wires, just to rule out an open circuit, and check for a short also.
View attachment Parking and Back-Up Sensor Connector.pdf
View attachment Parking and Back-up Sensor System (KA USA DE4) (Collision Avoidance and Parking Assist Systems).pdf
