Shift knobs anyone?
I got sucked in!!
went through a few shift knobs (skunk2, acuity poco insulated white and black), acuity collars (red/black/stainless), and finally settled on FK8 Type-R knob with stainless acuity collar. (but damn, now that I'm looking at these pictures, I'm rethinking that skunk2. and see how it looks/feels with those acuity collars ?)
Skunk2 OEM collar
Acuity Poco Insulated White
Acuity Poco Insulated brushed black
OEM Knob with Acuity collars
FK8 Type-R with Acuity collars
Love the Skunk2. I'm actually taking a HR Chicane knob locally to have it custom made into the Skunk2 appearance.
Westhaver
2024 ITS
Gray/silver with a red HybridRacing boot collar
I've seen a few people comment on your shift boot and ask if it was from an FL5, I think this is because your shift boot seems to be upsidedown/reversed from all of the others I've seen. Ie. most have two stiched seams closer to the cupholders, while yours has two stiched seams closer to the wireless charger.
tallboi
Jim
Twin Cities, MN
Raceseng Nitro. It's wider than the stock shift knob and I prefer the 'feel'. Our temps can be as low as -20F in the winter and as high as 100F+ in the summer so the hybrid design makes sense too. The dealer installed it free of charge when I took the car in for a warranty item so I have no idea if it was easy or difficult to swap.
Acura Integra Shift knobs anyone? IMG_5711
This is a great looking knob. How does the dimpled plastic feel? Substantial and nice, or cheap at all? Where'd you get it? Sold out on Raceseng site. Did you buy the collar adapter too or is that just the knob up against the trim ring of the shift boot? Thanks for the input.
tallboi
Jim
Twin Cities, MN
It's a very nice, high quality shift knob - nothing about it feels cheap. My first impression was that the transition between the metal core and the Delrin cover felt "sharp", but I quickly became accustomed to the 'feel' and I don't notice it at all.
I bought it directly from Raceseng. Try contacting them directly. The knobs were out of stock when I first looked, but they told me that more were on the way and recommended that I just keep an eye on their website.
I didn't buy the collar adapter. What you see is the knob up against the OEM trim ring.
so, just out of curiosity, how does the knob stay secure, is it just threaded on until it stops, vs. having the lock nut in place? I would think for proper alignment you would need the lock nut.
Looking at the picture it almost looks like the numbers are at a slight angle, because of this. It also looks like the knob is lower, as the boot appears more squished down. May just be the picture angle though.
tallboi
Jim
Twin Cities, MN
I assure you the numbers are not at a slight angle - it's just an artifact of the photo.
The knob screws onto a threaded adapter which screws onto the shifter arm. There's a set screw in the top of the threaded adapter that you adjust up and down (out and in) in order to adjust the final orientation of the engraving on the top of the knob as it screws onto the adapter. Maybe this will make more sense...
https://raceseng.com/pages/threaded-adapter-install-guide
The Nitro knob may be a bit shorter overall than the OEM knob, but I dunno if it's squishing the boot. I guess I didn't pay that much attention to it before.
very cool! That in turn allows you to skip using the oem locking nut we have.
I was looking at my dream knob and thinking it also looked a little sideways when looking at it from the side.
Thanks for the explanation. I need to clean mine up now!
bisquick
Brandon
TXWayne
Wayne
DFW
Acuity Poco Insulated. It sits lower on the shifter so you end up with shorter throws, which is a good thing IMO.
I was having a hard time figuring out what kind of shift knob I wanted but I think I found a winner. Thanks! Does it require removing the center console to install the new shift boot collar?
Yes, but super easy. I just did mine yesterday. Hybrid Racing collar. so much nicer than stock!!
TXWayne
Wayne
DFW
Great, thanks. I am sure I can find a YouTube covering it. I was looking at the Hybrid Racing collar if I was going with the Mugen but in looking at the Poco knob I think I am going that route and it comes with it's own collar.
Yes, the center console just snaps right off, then you can kind of flip it over without even unplugging any of the wires and get to the bottom of the shift boot. There’s a little zip tie, holding the existing collar on that you can kind of just pry over the top of the collar. Then you just slide the new one in from the top and put the rubber band around the edge. It’s super easy.
