Cruise control in heat
Respect
JJ
Las Vegas
2024 Integra A-spec w/tech
Hi all! New to the group-thanks, in advance, for the feedback.
So I picked up my A-spec/6MT in December and have really enjoyed it-my first ever Honda product, after years with Mazdas, VWs, and Audis. This is also my first car with a lot of the latest tech, save for the occasional rental car, so I am at least familiar with most of it.
I have two questions:
1. Cruise control: I saw the thread regarding using it in below freezing weather but, on a three hour road trip in the southern Nevada desert yesterday (110+ degrees Fahrenheit), the cruise control would abruptly shut off ONLY when I would resume. This happened at slightly over the speed limit on a 45mph undulating two-lane and a 75mph freeway. ACC was not on (not a fan) and it otherwise had no problem setting and holding speed initially. It WOULD reset either manually accelerating back up to range and setting or resuming within a couple mph. It would shut off and ding but no warning lights or messages. Chalk it up to extreme heat?
2. Acceleration in gear: I enjoy the rev match on downshifts. On upshifts, I have read that Honda manuals rev ever so slightly for a smoother gear change, and have noticed this. What I am experiencing may be tied in but wasn’t sure. When I accelerate somewhat quickly but without downshifting, the car seems to increase RPM before actually putting the power down-it feels like accelerating with a CVT. Is this normal? Oddly, I’ve only noticed this as it’s been hotter outside but that could just be my attention span.
Thank you!
For your #2, it is rev hang. Very annoying, but seems to be normal for all Hondas/Acuras with the M/T.
Was the sun in front of you?
Thats a good point. If the camera system has difficulty it disables these convince features.
Usually this is seen with snow, heavy rain,fog, etc. The sun or a bright reflection causing extra glare into the camera could be a possibility.
Respect
Respect
JJ
Las Vegas
It was more overhead, around 2-3pm. ACC was off though.
Fred 930
Fred
Wisconsin
VW GTI ; Acura Integra Type S
On upshifts, I have read that Honda manuals rev ever so slightly for a smoother gear change, and have noticed this. When I accelerate somewhat quickly but without downshifting, the car seems to increase RPM before actually putting the power down-it feels like accelerating with a CVT. Is this normal? Oddly, I’ve only noticed this as it’s been hotter outside but that could just be my attention span.
Thank you!
The "Rev-Hang" you describe (RPM increases when UPshifting) is in my opinion a design flaw that apparently is common in Honda and perhaps also other Japanese vehicles (I noted it in an Infinity several years ago). No one has yet explained why they chose to do this. It would seem to be absolutely the wrong thing to do - actually, the engine should DECREASE in RPM - perhaps 500 RPM or so - to match the next higher gear - which is the norm. What Honda / Acura has implemented would seem to create unnecessary clutch / drive train wear and irritates vehicle occupants. I hope Honda will someday fix this behavior, but I'm not optimistic. With only 1000 miles on my Type S, I consider this to be the "worst", most annoying thing about an otherwise wonderful car. It may eventually force me to look for an engine tuner, but tuning has negative warranty implications.
FW14B
Thomas
2024 Integra Type S, White/Red
It is for emission reduction. Many modern cars, including Japanese and German cars, have this issue. This video explains it.
Fred 930
Fred
Wisconsin
Thanks for the EE link on Rev Hang!!! Jason is the #1 creator of excellent technical automotive web content - I know of no one else with his ability to explain complex mechanical issues. He is the best.
But this video spends most of its time justifying electronic throttle bodies (which have been around for a long time) versus their older mechanical equivalents. Not to argue with Jason, but most of those electronic systems do NOT have excessive Rev Hang - I've had manual transmission cars my entire life, and have only once before noted this problem.
Rather, it seems to be related to how the manufacturer chooses to close the throttle in response to user command (your right foot). While it's probably emission related, I know many people with modern German cars (in fact most of my friends have German cars)- none have complained about this, at least to me. From my admittedly limited experience, this is mostly a Japanese car problem - and one that needs to be fixed.
That said, a friend recently related a story about one new Porsche model which is having clutch problems. There was some speculation those early clutch failures are related to Rev Hang - so maybe they decided to follow the Japanese for some reason??
Adios Amigos
Integra 1.5t
I drove to Los Angeles in similar weather and the lane keep assist and cruise did shut off on me one time. Was a good lesson in not fully trusting the system. Outside temp was around 110.
Mr. LargeCoffee
Liverpool NY
Rev hang has been around for a while. My 1976 BMW 2002 had a dash pot on the carburetor to slow down the revs dropping. Easy solution, remove dash pot. Unfortunately it’s buried in the electronics now and would require reprograming of the ECU.
Respect
Respect
JJ
Las Vegas
So, for anyone who wants to follow along…
the problem got progressively worse. As I drive mostly highway miles, I didn’t notice until Sep.
I was caught in stop and go on the highway, because of an accident. When I passed it and everything opened up, the car wouldn’t accelerate. I frantically shifted between gears and modes, barely moving , taking a good minute to get up to a safe speed, feathering the throttle and clutch. As I was coming due for an oil change, I made an appointment and reported the circumstances: first 15 or so minutes are fine and only if the car has been off for some time. The longer the engine has run and the more stop and go (even regular in-town traffic), the worse it gets. Of course, they couldn’t replicate the problem and said I must not be used to the adaptive cruise (which is not in use) or the rev match. I knew this was bs, the car was fine for the first ~15K miles.
A few weeks later (12/13), I decided to intentionally do some driving in town and made sure I was relatively close to the same dealership. As expected, it was horrible, the car wouldn’t get out of its own way. I called and they said come in immediately. They started to drive and agreed. As it was a Friday at 4, they said they probably could not do anything diagnostically until Monday but still hooked it up and gave me a loaner.
The following Tuesday they said they would need to contact Acura national tech service. On Thursday, they said tech determined it was owner’s fault for overheating the clutch and that it would not be covered under warranty.
Needless to say, I was furious. I’m no professional driver but I have been driving only manuals for 33 years. I have elevated to national Honda customer care but was warned, with the holidays, it may take a week or more to resolve. I have not authorized repairs and still have the loaner.
I know they “don’t build them like they used to” but, unless I’m taking it to the track every weekend, that clutch should last at least close to what the last two clutches I’ve replaced (Audi and Mazda), at over 100K miles. As noted previously, I know this car has a lot more tech than what I’ve ever utilized, but it seems like clutch slipping would always occur, not just when the engine is well warmed up. It also doesn’t seem like it would affect the cruise control, when only adjusting a couple MPH.
I feel like I’m getting gaslit by the dealership.
If you’ve hung in this long, thank you, and any feedback is appreciated!
hmmm, that sucks. time to hit google hard and see if you can find any other instances of this behavior. Also maybe try another dealer?
