integra__gang
- Thread starter
- #1
I’ve been tryna find what is causing this issue for the longest with no luck! Car has rough idle, and start ups. I’ll attach a video
It also throws misfire codes on start up. The problem is more noticeable on pump gas and e-mix compared to straight e85, pretty much on only ethanol the idle is better but if I add gasoline to the mix the idle gets rough (rough start/ long cranking is always there no matter the fuel type) I also got this idle code p0507 a few times thinking there was a vacuum leak and I did find my catch can hoses to be brittle which I replaced but it’s still causing it.
I even used a smoke test and there’s no vacuum leaks except for the one I replaced the hoses on the catch can.
the car drives perfectly fine but it’s got to the point where it’s so F-ing annoying having to deal with that and I don’t know what is causing it. I even changed spark plugs and swapped coils with my friends FK8 type r with no noticeable difference. I just don’t want to spend any more money on it without knowing if it’ll solve it or not, I’m just guessing at this point.
this is my mod list;
PRL high flow intake
PRL charge pipes
PRL intercooler
Catless downpipe
Front pipe
Hondata’s CANflex fuel sensor
Flashpro/jailbreak
Catch can
If anyone has has this issue and solved it please help, I can’t find any one else that has had this issue before.. btw my car has 28k miles.
Also the website isn’t letting me upload the video I’ll try to upload it as a reply to this thread
PRL charge pipes
PRL intercooler
Catless downpipe
Front pipe
Flashpro/jailbreak
Catch can
