gohan408
my all seasons dws06 only lasted 15k milesGot a quote for new tires cause my Blizzaks only lasted 1.5 seasons
If anybody got some all seasons to donate let me know![]()
Yeah mine are heavily worn on the insidewith 20k on them. I really need to pull camber out.my all seasons dws06 only lasted 15k miles
no it just didn't show for shit last year and this year so far it's been 30 and above for the first halfThat seems oddly low for blizzaks unless you drove them through summer![]()
Nice seat! I have a Pole Position (replica) in my S2000 and the seat belt rides up on my neck because I'm short. I got one of these on Ali Express for less than $4 and it works great. Just look for "seat belt guide".![]()
Recaro SRS ASM Limited installed. Recaro has a seat rail package for FL5 that I used, itβs an adapter frame that attaches to seat, then the rail attaches to the adapter frame. Purchased everything from @lmtlsauto (thanks Luigi!). Ordered beginning of May, arrived beginning of January. No SRS light, but not as straightforward as I thought. I was trying to keep the stock seat harness intact but ended up cutting some wires, specifically the ones that donβt have connectors visible from the bottom of seat; kept the harness as intact as possible. I did that because the seat position sensor is bundled into the harness that also contains seat heater + power seat controls; the seat position sensor + SRS delete + seatbelt sensor are needed for no light
Thanks! Iβll check that out. Currently the seat belt doesnβt ride up on my neck, but Iβm planning to remove the adapter frame attached to the seat rail to lower the seat a bit, by about an inch, I might need it then. Also, I picked this up a couple months ago, thought you might like this:Nice seat! I have a Pole Position (replica) in my S2000 and the seat belt rides up on my neck because I'm short. I got one of these on Ali Express for less than $4 and it works great. Just look for "seat belt guide".
That looks really good!Yesterday....
Accord Homelink mirror retrofit
Your S2k isThanks! Iβll check that out. Currently the seat belt doesnβt ride up on my neck, but Iβm planning to remove the adapter frame attached to the seat rail to lower the seat a bit, by about an inch, I might need it then. Also, I picked this up a couple months ago, thought you might like this:
Fits the car so well. How's comfort for longer drives? I think I'd have a hard time giving up any adjustments, I fiddle with lumbar support every other day.Recaro SRS ASM Limited installed.
I havenβt done any road trips or anything, just a 30 min test drive after install and work commute (20 mins one way). The seatβs comfortable and supportive, especially during spirited cornering. Much more than the stock seat. I feel like a race car driver and I love it. Iβm a set-and-forget seat setting type, but I can see the disadvantage of the loss of adjustability. Might not be for everyone, just the ones that wanted a better performing seat (better than the stupid FL5 and its stupid stock performance seatFits the car so well. How's comfort for longer drives? I think I'd have a hard time giving up any adjustments, I fiddle with lumbar support every other day.
Can you still use the skid plate?First oil change at the dealership, steering recall, and Rsplitters aero installed this weekend. Super happy with how it looks. Only took pictures of the front but splitters installed all around. Had to remove this little aero piece on the inside of the front bumper but guess people remove it when installing aftermarket intercoolers... a bit more incentive to upgrade that
Front bumper interior aero piece removed and where it would normally be:
To install, skid plate doesn't need to be removed or touched.Can you still use the skid plate?
This makes me wonder if the HRC intercool will come with a different aero piece.
Man, that apex blue is too prettyCan you still use the skid plate?
