Windshield washer not so good
Apex_ITS
David
Minor issue just curious if anyone else noticed this.
Basically the windshield washers put a small amount right off the blade but just swipes it all to the sides instantly and doesn’t really clean. Have to do it a few times.
asked the dealer and they said it was normal.
First car with washers on the blades, is this just normal?
All my other cars had the nozzles on the hood and would soak the windshield.
Car00071
St. Louis, MO
I think this is normal, we just have to use a few more swipes but I believe it doesn’t spray as much every swipe compared to the traditional mounted nozzle setup.
It's different but fine. If you want your windshield to be actually clean you still need to wash the car, as always.
Apex_ITS
Apex_ITS
David
yeah I’m just used to my F-150 soaking the windshield.
Just wanted to make sure it was working right.
nix6speed
Houston
'24 LCM ITS
That's why Acura gave these a tiny gas tank. Next fill up you'll be able to conveniently squeegee the windshield in no time!
I tried it once and was not happy either. I wanted some to get on the windshield on the down stroke. Maybe just need to keep it going longer.
vovakovtun
Atlanta
I lightly polished all windows and applied aquapel glass treatment after the first wash. Never had problems with sprayers on the wipers. The only reason I miss regular sprayers is when I want to spray tailgaters.
RIP for the free windshield washer fluid. :p
If you want a larger windshield washer tank swap it out for one from our Northern brothers. Canadian integras get an extra litter or more of capacity
Rain x and remove the tank and wipers. Hell the weight reduction and areo. Should add power too😉
🤔 I like the rear wiper deletes.. maybe your onto something 🤣
I tried the washer again today. It's reasonable for the driver's side, but the passenger wiper doesn't spray fluid on the down stroke, (neither does driver side so it's basically spraying on the way up and not quite doing a good enough job. I tried just letting it spray the whole time and it wouldn't do it, just on the upstroke. weird...
