Yokohama Advan GT Beyond 275/35/19
Underdog
Massachusetts, USA
‘24 ITS, ‘06 Legacy GT
Here are some pics of mine 19s in Racing Titanium Black
This looks great. No issues at all with the 275/35-19 and +45 at stock height? I went with a +51 wheel and am also keeping the car stock height for the time being. I like how the 35 profile fills the wheel arches, and gives more protection against crappy roads.
Scrodee
CSRA
'24 ITS in LCM
I can't find the weights on the Advan wheels. What was the weight on this setup?
275/30 will be a closer fit to stock outer diameter and they will fit fine. 275/35 will definitely fit on the rim but the sidewalls will be and additional 16.75mm tall or 2/3rds of an inch. Will throw off the speedo but would probably look good and meaty.
PLovin80
Virginia
@notorious9i6 Do you think 265/35 19x9.5 +38 would fit with eibach sportlines (1.2" front, 1" rear drop)? Essentially its a more aggressive drop than the h&r's with 7mm more poke than your +45 offset.
^^ I want to know this!! Would love to go 275/35 19, with drop and +45 offset.
PLovin80
Virginia
265/35 19x9.5 +38 ... Mathwise it should fit.
For sure 275/35/19 +35 will rub in the rear.
Thanks for the reply. I feel a bit better now. Your post is very helpful for comparison.
265 is a bit short and narrower than 275, which is good for my clearance, but the extra 7mm (0.3") poke and being about half an inch lower is concerning me.
Do you feel if your wheels stuck out another 7mm and you were half and inch lower, you would still clear the outer fenders without rubbing?
Also, my camber is -2 front and -2.5 rear.
