Accessory-off delay (after shutting off engine)?
6mtJak
Jack
2023 Acura Integra Aspec 6mt
Hey All -
Is there no option for accessory off delay? As in when you turn off the engine but the radio continues to play until it times out (like 20m) or you open your door.
Tia -
Not that I know of for the 6MT. There’s nothing in the user manual or online. I believe I saw something for the CVT model. I guess you could always trade it in for one.
All jokes aside, maybe a third party releases a module to address this. It would be very helpful and convenient.
6mtJak
6mtJak
Jack
For all the awesome tech in this car there are some weird omissions
Nooo I fucking hate that feature. So glad it doesn't exist. You know what would be better, give us a normal key so we can choose what we want to do with our shit. Push start doesn't work half the time anyway.
How often have you had push start fail on you?
Maybe one out of every three tries it doesn't go on the first push. It could be that the clutch wasn't all the way in or I didn't hold it long enough, but the resultant beeping and treating you like an idiot is not what anyone wants out of a car.
That doesn't seem right. Out of many pts cars I've owned I've only had an issue when the clutch release sensor (top clutch sensor not lower depression sensor) was bad from wear. In this car it starts every time so far.
Could it be a bad sensor?
I'm pretty sure I'm just ham-handing it. When you're slow and deliberate it works as it should, but if you're trying to hurry it slaps you down and reminds you who's in charge. Never had this in any keyed vehicle. I'm not the only one who finds this thing picky.
cchan383
MA
Acura Integra
This car is a little different than other manuals I've had. It's not that you have to hold the push start down for awhile but rather need to have the clutch fully depressed down until the cluster completes the start up needle sweep as it settles into idle. You're probably releasing the clutch too quickly after startup, I don't think it's the push button.
Banned
Banned
Adios Amigos
Integra 1.5t
You have to shut the car off and leave your finger on the button to push it again if you want it to be in aux mode.
Mr. LargeCoffee
Liverpool NY
It seems like every car I’ve had for the past 30 years allows the accessories to work 3-5 minutes after shutting off the car as long as you didn’t open the door. Can’t understand why this isn’t a feature of the Integra. I could swear that the Honda Fit I had 15 years ago did this.
Strange. I have not had an issue and just depress brake and clutch then press the button fully. Start right up every time. Now if you release the clutch before it's fully started it will terminate the starting
Windows can still be oprated in the Fit after you shut off the car. But the radio won't work...
