Same (but all around). They are so squeaky lol
Yes, the Jury is still out, but I like their performance. I’m not sure I have them totally bedded in just yet. Also still had some deposits left over from the R5 at the Track.
dockleryxk
Richard
East TN
What was your bedding procedure? My rears weren't for sure, but everything got quieter when I bedded the fronts (rears were on already).
Also, I'm being dramatic. They're not that bad
I followed the exact betting advice from paragon for both the R5 and P3 pads. 35 mph to 5 mph medium pressure, 8 to 10 times. Drive the car 45 miles an hour for 7 to 10 minutes. Then three more stops 45 mph to 5 mph, then drive the car for 10 minutes to let the brakes fully cool. Did it out on back road so I could stay off the brakes. It worked like a charm on the R fives. Because of the pad deposits from The R5’s, , the procedure to bed the P3’s didn’t seem to go as well. I need to go out and do it a couple more times to clean off the rotors, then bed the P3’s. It should work once I get them cleaned off. Interestingly, enough, I had the R fives on the car for about three weeks in total, and they actually didn’t produce all that much dust, and they were pretty quiet both before and after the track.
dockleryxk
Richard
East TN
dockleryxk
Richard
East TN
How else am I gonna take 15 mph turns at 50?
That's the problem. You have the camber to go 50 in a 15mph turn but you're not doing it often enough, so you're wearing out unevenly.
For anyone looking at tire wear, you might want to get symmetrical tires so you can flip them when the camber starts to wear further on one end, especially if you're doing a lot of highway pulls or hard braking. High torque with a front heavy fwd car is definitely like a 911 for tire wear, just flipped backwards. Ultimately your tire pressure needs to be spot on and you should drive to the alignment of the car. This is not a car you drag race. If you want to be launching it and ripping through 1st and 2nd gear, take out camber for better grip and less inside wear.
Ps4s are technically a 30k tire that typically lasts 20k on sporty cars. It likes some camber but not too much. It also likes higher pressure than you'd think, so the factory specs are really a minimum. It wouldn't be unreasonable to air up before you plan to drive it hard, especially on the fronts. Low pressure and hard driving will wear out the shoulders of this tire very quickly.
speaking of pressures, I think I finally got the fronts dialed in at the track. Was rolling over way too much in the corners. Looks like 41 PSI hot is the sweet spot. 36 psi rear. This was on 275/30 summer tires. Bonus, the car seemed to settle down under heavy braking, once I got the front pressures up high enough. Still so much to learn.
