That's good to know. I've definitely been experimenting with tire pressure lately. Sounds like I'm too low. On the 275/35/R18 tires in my pics, I was running around 34 PSI front and 31 PSI rear (cold). Sounds like that might be a tad low.
Thanks for the info! I'll try some higher pressures when it's time for summer tires again.
With 18s your load rating is also much higher so 29psi is equivalent to 35psi in oem load rating.
On the 265/30/19 i found 44/40 to be pretty well balanced at the track, but it will change depending the surface and track. I could have further tuned driver front to 46, passenger 43, rears 40/40.
44psi on oem tires is 34psi and 40 is 33. Sounds like you're not terribly far off, but if you're on 9.5" wheels you might need that bumped 2-3psi still to account for the significantly wider tire footprint (the oem 265 dt1 is narrower by 3/4" than 265 regular ps4s so the 275 is i bet a whole 1" wider).
dockleryxk
Richard
East TN
Thank you!! I will definitely give it a shot. I'm on 265/35/R19 now for the winter with all seasons, so I'll add a few PSI for now anyways. Won't hurt the gas mileage haha
To be honest I'm not too fussed as long as I've got grip and I'm able to get the car to turn in/rotate nicely. Lower rear pressure than front definitely helps, but you can definitely go too far with this LOL
You're correct. There's definitely na point of too far. I usually base my pressure of how the tire is wearing when I don't have a proper tire pyro on hand. Too much wear at the edges - pressure up, too much wear in the middle - pressure down, not enough turn in rotation - pressure up rear or down front, outer edge rolling over - pressure up or more neg camber (situational), inside wearing too fast - pressure up or less neg camber (situational), and lastly if all else fails but tires are wearing unevenly, then toe spec needs adjustment in or out.
265/30 @ 35psi = 265/35 @ 30psi. Check out tiresize.com/pressure-calculator.
Here's mine at 3k. 9/32nds left in front and 9.5 back. One track day with a very rough surface and approximately 120 laps. The wear is even and camber correct for track use. Street use and hwy pulls would need some camber taken out.
And here's a ps4s from another car with 8k mi on it and 7/32 left. You can tell it's a lot cleaner looking because that car doesn't see track time, unless you count my wife ripping it from daycare to her work as track time.
you'd be surprised how aggressively some mom's drive. i always see them absolutely flooring it once lights turn green.
Not too surprised, 😂. There's a reason wifey leadfoot got a supercharged v6 q7 and a set of ps4s on 22s. And it's the same reason I just got new Porterfield r4s pads to replace the oem brembo/textar setup for her, lol.
Fun fact, a simple tune on that engine nets 450hp crank, up from 333 factory. Tuned it can hit 60 in 4.1s and the quarter in the mid 12s. It makes a phenomenal tow vehicle.
